Tool Question
/ Tool Question #1
Lynkage
Denver
Kubota L48 w/sims steel cab
I hope this is the right place for this.
Can any TBN member give any real world advice on Gas concrete saws. I am looking to get 1 of 2 saws.
1) Stihl TS400 14"
2) Makita DPS7311 14"
I have read great reviews on both but I would rather ask here because TBN'ers are great people.
I will do mostly concrete cutting. I also know these machines are destine a hard life.
I will most likely cut some stone, metal, brick and others.
I have a Stihl MS 270C chain saw that has been GREAT, but the Stihl saw is $300 more than the Makita.
Please help.
Shane
/ Tool Question #2
I've used that Stihl model quite a bit and it is one **** of a saw. The plus side of buying the Stihl is you can get all your parts the same place you can get your chainsaw parts and don't have to hunt for a parts source.
I've never used the makita so I cant somment on it, but what I will say is that stihl makes some very good equipment, mostly all of which is gas powered and has a very good reputation of manufacturing very durable commercial equipment. Chances are the Makita is made by another company and it has a Makta name on it, but I am speculating on that.
/ Tool Question #3
I work at a road construction co. we use the sthil. it's a great saw..
soundguy
/ Tool Question
The Makita is a Wacker (rebranded). I do know Stihl is very good equipment. (heck I own one) but the reason I ask is because Home Depot rents them and they say they work very well.
So far it looks like people are using Stihl. I do not think this is a bad thing.
:D
/ Tool Question #5
1) Stihl TS400 14"
Please help.
Shane
There are many good ones. I have used Sthil, Husqvarna, Shindawa and Partner. I own none of the gas but do own a Partner electric which quite frankly impresses me so much that I doubt I will ever have a need to buy a gas saw. I love the instant on, no fumes and light weight. I notice very little difference in power. The Partner is a true electric cut-off saw designed that way, not as a angle grinder converted to one. Soft start, electronic current monitoring, its great unless you don't have a power source then the gas is a superb alternative. I have the 14" Partner. The price was also quite a bit less then gas.
/ Tool Question #6
The Pardner gas saw is a very wel built unit too! If I were buying one I would get a Pardner or Stihl, the deciding factor would be price.. as both are top of the line saws.
A good friend of mine owns a rather large concrete business, all of their saws (all are gas) are Pardner and Stihl, with one Hilti (bought it through some sort of dollar back deal for spending about $100k with them in a year). Honestly I used the hilti and was not impressed with it, it may have just been a bit out of tune or something but it wasn't the saw the Pardner was.
/ Tool Question #8
:D
I worked as a service tech for Makita for 15 years, up until 6 years ago. Around 10-12 years ago Makita bought out the German co. Dolmar and over time changed the colour from orange to blue. As far as I know the gas cut off is still a Dolmar. Maybe they are using someone Else's saw but I would doubt it. I will find out for sure in the next day or two as the Makita guys are still friends of mine and they will know for sure. As far as which is better I really don't know. I have used Stihl products for over 25 years and had great success. The Makita/Dolmar I did the repairs on but have never owned or used one much. What I can say though is I never had reoccurring problems while I was the service tech in our area for Makita.
/ Tool Question
Thanks for the info guys. I was looking at one of the electric ones (Makita) and it looked good as well.
I will most likely not use this tool very much but (just like my tractor) I hate to rent stuff like this because it is expensive. If I rent 5 or 6 times I have bougt one.;)
/ Tool Question #10
Rent one 10 or 12 times then you will be able to buy a saw and a blade... a good diamond blade will run you a few hundred dollars.
/ Tool Question
Here at a place about 5 blocks from my house they have MK 14' blades for $80 makitas and hiltis at $129 and Dewalts for $150.
They do pretty well on ebay. It is called Tool King.
/ Tool Question #12
Blades come in very different configurations and vary considerably in quality. MK makes good blades and they make "cheap" blades. A concrete blade is very different then a rock blade and very different from a asphalt blade. Some can be had for well under $100 and some will cost over $500. Once you use a high quality blade, the cost difference is easily made up in speed of cut and blade longevity.
Here is just a small sample of some of the blades available...
Asphalt, Green Concrete Blades - Toolfetch.com
/ Tool Question
I certainly understand this. In my MK 100 series tile/brick saw I use MK blades and they run me about $120 each. but if you keep them dressed they work for a long time. I am sure that the MK in question is a cheaper blade but for the amount of use it will see it could be a viable option.
/ Tool Question #14
I have the Makita saw picked it up for $850 including diamond blade & 4.5" angle grinder.
Runs like a champ - used it to make some holes in my basement for footings thread here
Also on the pool demo project although the volvo backhoe mounted hydraulic hammer was more impressive.
Tip - don't run the diamond saw blade in reverse, it may ruin it. A buddy re mounted it after using an abrasive cut off blade to cut rebar. It don't cut like it used to:mad:
/ Tool Question
Thanks Hazmat!!
It is nice to see someone with a makita to hear how good it is.:D
Thanks Shane
/ Tool Question
Update
I got a Makita 7311 for $700 new with a hammer drill.:)
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
Dueling Tree (A65640)
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
