Tool for Grubbing Stumps
/ Tool for Grubbing Stumps #1
critter1
Hey Guys, I don't want to re-invent the wheel, so I need help. Just purchased 10 acres that is primarily hardwood timber. The previous owner went through the plot with a shredder and took out everything three inches and less. Now I have a lot of small stumps that need to be grubbed out of the ground. Have a L3130 and thought I might adapt an old middle-buster to do the job. Seems like I could just back up, over the stump, set the "adapted" tool into the ground, then pull the stump and root ball out, while lifting with the TPH. Surely, somebody had come up with a good tool to accomplish this task. Any ideas ? Thanks
/ Tool for Grubbing Stumps #2
If you can weld - make yourself one of these:
Tree getter - more info here pushing back the woods
You can also search for "tree getter" and find a few other versions.
/ Tool for Grubbing Stumps #3
An unmodified middle buster would likely not have enough strength to hold up. Maybe a strong single shank subsoiler would do the trick of ripping it out by the roots. I had to grub out a 3 or 4" tree a couple of days ago. I used my grapple rake and got the tines deep in and under the roots and popped it out. Of course I made a 6 1/2 foot wide hole in the process!!:eek:
/ Tool for Grubbing Stumps #4
Several methods come to mind.
First, if you have access to a backhoe that would likely be quickest.
Second, a grapple, especially the curved type known as root grapples should be able to do this work if you FEL is strong enough (lift >1000lbs at pivot points roughly)
Third, there are specialized FEL grubbing buckets that are triangular or trapezoidal in shape that allow you to dig under the stump and lift it out.
Fourth, you could do this with a tooth bar on your FEL although it would not be terribly efficient as you'd end up digging a wider area than desired.
Fifth, I don't think this is a commercial product but if you search on TBN you can find an example of a relatively simple welded device that attaches to the 3PT hitch and has a rear facing V shaped jaw at near ground level which allows you to back the tractor so the jaw engages the stump then use the 3PT hydraulics to pull it up.
Others may have additional ideas.
(Edit: I see that Hazmat has posted an example of the fifth device I was referring to)
/ Tool for Grubbing Stumps #5
For 3" and less stumps - I vote for FEL with toothbar if you need to see immediate results and already have a FEL - otherwise - leave them be and they will probably be gone in a year or two anyway. 3" stumps from saplings I cut two years ago can be kicked out of the ground with my foot - just make sure they aren't green stumps if you kick any :)
/ Tool for Grubbing Stumps #6
The back hoe would be the best. However you siad that you have 10 acres to do that is going to take a long time with compact backhoe and you will most likley have some repairs by the time you finish ( busted lines, broken welds, ect) If it were me i think i would rent me a small track hoe or good size mini excavator with a thumb on it. Thoes things can literally pop them right out of the ground. Where a backhoe you are going to have to dig around them. Especially if they are any kind og hard wood with a deep tap root.
/ Tool for Grubbing Stumps #7
Here is one that I think would do a good job.
/ Tool for Grubbing Stumps #8
I built a tree grubber that works pretty good. Pictures aren't the best but you get the idea. I'm usually grubbing trees but it will dig into the ground and grub a stump if needed.
I built one for my buddies 100HP tractor. I used 8" I Beam and 4" square tube. My little Bota won't tear up the one pictured but I didn't think it would handle my destructive buddy!!!
/ Tool for Grubbing Stumps #9
How does that one work? It looks to me like the v cut/blade is facing towards the 3pt hitch instead of rearward which is what you'd need to back up to snag a standing tree. I guess this style would work fine with stumps as you'd just drive over them but it would be kinda tough to lean backwards to look down to see you were properly lined up while moving forwards.
/ Tool for Grubbing Stumps #11
I use a ER series single shank ripper made by Rankin equipment http://www.rankineqco.com//pdf/singleshankrippers.pdf with just the bare shank(it came with the plow blade for making furrows). It is pretty robust.
I use it almost exactly like you describe for small stumps and bushes. For the ones I think have a more extensive root system, I will sometimes rip along either side of the stump to cut roots then I back over the top a bit so the shank has room to get under the ground and wedge into the roots. I do this in creeper gear and as soon as I feel things getting tight and the tractor slowing I lift the 3PH and this usually peels the root wad right out of the ground.
/ Tool for Grubbing Stumps #12
Island is on target. I made one using a BB ripper and fashioned a "V" in a 5" square peice of 1/2" plate. I made a mounting gizmo that I also use with a gable plow made of a ripper Some one on this sight had a good pix. Also I think backing and lifting is best for sapplings, I can also see for small stumps how that red one would justgrab on after you drive over, pull drop and roll on to the next. Mine works great!
Neil
/ Tool for Grubbing Stumps #13
From what I understand it is for stumps and roots. You have a lot more advantage going forward.
/ Tool for Grubbing Stumps #14
JerryG is right-for 2 reasons. 1. Tires are designed to pull with most traction in forward direction. 2. Three point hitch works better, and is stronger in extension mode (pulling forward). Pushing a three point implement is a good way of bending the lift arms or toplink.:eek: :eek:
/ Tool for Grubbing Stumps #15
I appreciate Jerry's and your points. However, for the small sapling type stumps that the original poster described, I'd think that the strain on the 3PT would be minimal if you are just jamming the V to get a grip and that traction is not an issue as you are really just using the 3PT to lift the things out of the ground.
The forward acting plow device certainly looks formidable and probably doesn't use the 3PT to lift at all but lining it up an an individual stump seems a bit more tricky.
Thanks for the input, gentlemen. I think that the Harris Root Plow, like the one suggested by JerryG, or a single shank ripper, would serve me best. The area is so heavily wooded, I'm afraid that the FEL would create more collateral root damage to surrounding mature trees, than the smaller type implement. Also, I feel that pulling forward and lifting will be more efficient and less likely to bend the lift arms. As always, the feed-back on this forum is fantastic.......thanks again, to everyone.
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
CAT R500/D9R Ripper Teeth (8) (A68134)
CAT R500/D9R...
2007 PETERBILT FLAT TOP SLEEPER  385 (A67714)
2007 PETERBILT...
PALLET OF DISCHARGE HOSES MISC SIZES (A68842)
PALLET OF...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
PORTA POTTY (A67714)
