Tool cat phone holder recommendations
   / Tool cat phone holder recommendations #1
danielcarm85
Toolcat
Does anyone have recommendations on a good cell phone holder and placement for the (2023) tool cat?
Thanks
   / Tool cat phone holder recommendations #2
My left shirt pocket holds my cell phone. ;)
   / Tool cat phone holder recommendations #4
RAM X-Grip. I use it with their twist lock suction cup base, but they have various other base options (clamp on, screw down, cup holder, etc.). Modular system that you can configure any way you want, and it stays put.
RAM X-Grip
   / Tool cat phone holder recommendations #5
RAM X-Grip
That's what I use in my L4060 and truck. The tractor uses a round bar mount on the interior door bar, and the truck mounts in a "can" that fits in a beverage holder.
They make quality stuff.
   / Tool cat phone holder recommendations #6
I used RAM components with with a PEAK magnetic Phone charger. Uses an existing bolt on the side panel cover so nothing new to drill.
Plugs into the USB C port built right into the dash with the included cable from the Peak charger.
It works great even bouncing around.
If your phone doesnt have MagSafe or MagFit then just swap out the Peak charger for a RAM X-Grip like mentioned above.
System is made up of the following components -
Peak Design Mobile 1" Ball Adapter Wireless Charging (Non-Locking)
RAM Mounts RAM-B-252U 11mm Bolt Head Adapter Ball Base with B Size 1" Ball
RAM Mounts RAM-B-201U-C Double Socket Arm (Long) Compatible with RAM B Size 1" Ball Components
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
BOBCAT 18PLA SKID STEER HYD COLD PLANER (A54756)
BOBCAT 18PLA SKID...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
(INOP) 1991 E-350 FLATBED (A54756)
(INOP) 1991 E-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
