Took the plunge - bought an XR4140H
   / Took the plunge - bought an XR4140H #11
Congrats! You will love it. Make sure you keep an eye on hardware and check things over periodically. Both control handles on my backhoe were loose (there are three socket head cap screws holding each handle to the valves). You will lose some hyd fluid when you change the filter but it isn't too bad. Other than that, it's a fantastic machine!
Thanks! Give me a heads up if you come across any other odd things coming loose.
I generally do a walk around on my tractor every so often and check hoses, belts, gaskets for leaks etc. I do check for loose bolts and nuts on occasion but will make more effort with the new tractor.
   / Took the plunge - bought an XR4140H #13
Do you might sharing what the 4140h cost out the door with the backhoe and brush cutter? I'm hoping to pull the trigger on the exact setup in the next few months.
   / Took the plunge - bought an XR4140H #14
Always a good idea to have a grease gun in your hand during your walk arounds.
You will like dealing with RCO. I bought my XR4046HC at their Austin Store in late 2014. Passed by two other LS Dealers to deal with RCO.
Which cutter did you buy?
Have 10 hours on the new tractor.
Love the difference in operation over the gear drive Kubota. There is a bit of learning curve on the HST transmission.
Bucket flop is a concern and I think I will be fixing it as in other threads.
Tried to mow the back area of my property and almost managed to get it stuck twice. Got her out of the mud by some miracle and took 30 minutes to get all the mud off.
   / Took the plunge - bought an XR4140H #16
Thats a sharp rig! Wish I could get the backhoe for mine. Nothing wrong with a
little mud on your tractor
I have found that my 4155 treads very lightly compared to other equipment I have used and does very well in mud with the R4's.
The underbellys are soft on these newer tractors. You may want to look into putting a skid plate on there. Pretty easy on these.
   / Took the plunge - bought an XR4140H #17
Congrats on your new tractor!
   / Took the plunge - bought an XR4140H #18
Hello BargainFittings,
I am about to purchase the same tractor and noticed you've had your for about a year and a half. Can you tell me your thoughts pro and con. I am also getting the BH. Which Hoe did you get, the LB2105 or the LB3104?
   / Took the plunge - bought an XR4140H #19
Hello MyLake
Getting ready to purchase the same tractor with the BH. So after a year are you happy with your machine? Which Hoe did you get the LB2105 or the LB3104?
   / Took the plunge - bought an XR4140H #20
Pretty happy with the LS. Have not used it as much as I anticipated, have 40 hours on it. I have the 2105 BH and may be interested in selling it, since I only used it one time. (Sell the BH, not the tractor).
Overall, I am still happy with how the tractor has performed. It is a good machine and I recommend buying LS.
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SCREENER (A58214)
SCREENER (A58214)
Rooster Weathervane (A55853)
Rooster...
2019 Chevrolet Sliverado (A55973)
2019 Chevrolet...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
