Took me less than two hours to
   / Took me less than two hours to #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
Bend the tie rod on my new CK30. Was there a new modified version on the latest CK25/30's for the tie rod placement or tie rod itself?. The one I have was a leftover 2006, couldn't pass up on trading in the old CK20 and moving up.
Steve
   / Took me less than two hours to #2
You've got the little te-rod. The newer ones are a larger diameter than the nuts. It looks interchangable with the only difference being the bigger rod diameter but I would rather bend the rod than break the hub ear.
Welcome to the club. Did you even feel it happen?
   / Took me less than two hours to #3
Highbeam said:
.......but I would rather bend the rod than break the hub ear.
I concur. I'd rather the rod be the weak link. It can happen on any tractor. One of my co-workers has a TC35 w/Ags, much higher ground clearance but he still bent his. If you had higher clearance you'd just try to drive over higher obstacles. Put it in a vise, bend 'er back, re-install and adjust alignment as needed.
   / Took me less than two hours to #4
You'll need some heat to bend it back unless you are super man. It is solid and very stiff. A new one is not too expensive. Heck, I've even got a new one on the shelf for a back up so they must not have been too much money.
Be careful not to rip the tie rod end boot when you pickle fork the end off.
   / Took me less than two hours to #5
How bout putting a chain around it, tying it to a tree and putting the gear selector in R for "repair" :~}
Theres always one in the crowd......
   / Took me less than two hours to #6
They have tie rod end pullers that aren't much more than a pickle fork and will save the boots on parts you want to reinstall, sometimes one can get lucky backing tie rod taper nut off flush and smacking it squarely with a hammer...given theres clearance for a good swing with a 5# hammer.
   / Took me less than two hours to #7
There's no need to straighten it; you'll just bend it again.
The tractor doesn't know it is bent, just adjust the toe in (about 1/2" as I remember, check) and that's it.
No kidding, mine even looks better bent, it looks like it was made that way to give the most clearance.
Mike
   / Took me less than two hours to #8
I haven't done a tractor tie rod yet, but many trucks and atv's. I always smack the side of the spindle with the hammer, not the tie rod stud. If the tires off the ground putting a little pulling pressure on the tie rod end the end will usually pop right out.
I also have a couple tools that works great for removing them as long as they fit the particular tie rod end.
American Presto TIE ROD END AND BALL JOINT REMOVAL TOOLS : JC Whitney: Auto Parts & Accessories
   / Took me less than two hours to #9
I let the bucket lead the way when I go in to un-charted territory.
   / Took me less than two hours to #10
Me too, even when brushhogging fields I set the loader down low engough to snag rocks or stumps before the tie rod. This also reduces hitting mole mounds with the mower.
John Deere 7500 Reel Mower (NOT RUNNING) (A50774)
John Deere 7500...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2019 Bobcat E26 (A50120)
2019 Bobcat E26...
Kubota BX2230D (A47384)
Kubota BX2230D...
