Took delivery of a CT2040
   / Took delivery of a CT2040 #11
I got the pair of rear remotes mostly to future proof against any implements that might require it. I'm probably going to pick up a hydraulic top link once i get my tractor.
which rear remotes did you get? Spring or detent?
   / Took delivery of a CT2040 #12
Spring for both.
   / Took delivery of a CT2040 #13
Spring for both.
Bobcat used to make a short piece of hydraulic hose that connects the two hydraulic ports together to prevent any issues if the detent were to be bumped into on position without anything being hooked up.
Not sure how big of a deal that is with the new tractors but seems like it could cause some problems if you didn’t catch it. I keep that hose plugged into my remotes that has the detent when I don’t have my backhoe hooked up.
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
