Took delivery of a CT2040
   / Took delivery of a CT2040 #11
I got the pair of rear remotes mostly to future proof against any implements that might require it. I'm probably going to pick up a hydraulic top link once i get my tractor.
which rear remotes did you get? Spring or detent?
   / Took delivery of a CT2040 #12
Spring for both.
   / Took delivery of a CT2040 #13
Spring for both.
Bobcat used to make a short piece of hydraulic hose that connects the two hydraulic ports together to prevent any issues if the detent were to be bumped into on position without anything being hooked up.
Not sure how big of a deal that is with the new tractors but seems like it could cause some problems if you didn’t catch it. I keep that hose plugged into my remotes that has the detent when I don’t have my backhoe hooked up.
UNKNOWN  UTILITY TRAILER (A55745)
UNKNOWN UTILITY...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
FUEL  TANK (A55745)
FUEL TANK (A55745)
ASCO Transfer Switch (A52377)
ASCO Transfer...
2008 Geringhoff NS800 8R30 Corn Head (A53485)
2008 Geringhoff...
8ft Fork Extensions (A55851)
8ft Fork...
