Too short tooth bar
/ Too short tooth bar #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I know there are a million posts on tooth bars, but I have a slightly different question I believe.
I need a 60" tooth bar for my bobcat and Tractor.
I found a 57" one at the local dealer I can get cheap.
I could cut and weld in the segment to extend it too the 60" length if needed, but I was wondering if it would even matter? I was thinking that I could just put in some longer bolts and some form of spacer on each side.
How critical is it that the tooth is against the edge of the bucket? Would it matter if it was set in 2" or so from the edge?
My thinking is that the side bolts on the tooth bars act more as locating devices then actually holding the stress of the toothbar, would you say that is a true statement? That is why I do not believe that it would be a big deal to run longer bolts and spacers.
Anyway, thoughts and input appreciated.
/ Too short tooth bar #2
I believe you would need to make the bar wider so you can mount it on the bucket. The bar bolts to the end, so unless you use a shim the shorter bar would not be long enough to bolt..
good luck
/ Too short tooth bar #3
Just how cheap is "cheap"? Have you ever priced one to fit correctly from Markham Welding or anyone else. If your only saving a few bucks it may not be worth the time and aggravation of getting something you have to mess around with to wind up with something you are not totally happy within the end.
My 2 cents.
/ Too short tooth bar #4
Personally, I'd put a spacer on either side and use that 57" toothbar.
/ Too short tooth bar #5
My vote goes for buying the "cheap" toothbar.
I had the same problem. The inside of my bucket measured 53 3/4" and the outside measurement of the toothbar mounting brackets was 52 1/4". I simply made spacers to fit on each end of the brackets (inside the bucket) and used longer bolts. It worked great and has never given me problems.
Send a picture after you've finished your project.
/ Too short tooth bar #6
Go with the shorter bar and use spacers if the price difference between the 57" and 60" is significant. You will need 2 spacers probably just shy of 1.5" each. That is no big deal.
/ Too short tooth bar #7
And please show a picture when finished mounting it, and tell us how it worked out. /forums/images/graemlins/wink.gif
/ Too short tooth bar #8
I think there is very little stress on the side bolts. My toothbar fits snuggly on the bucket edge and that is where the stress is. I wouldn't worry at all about using spacers and longer bolts. The bolts included with my toothbar are just standard grade 5.
/ Too short tooth bar #9
Usually a 60" bucket is the outside dimension. Your bucket will measure less than 60 inside. The cheap 57" should work well with some thick washers or metal spacers on each side. /forums/images/graemlins/cool.gif
/ Too short tooth bar #10
Alan;
Do you have a welder? You could just cut it in the middle and add a section to "space" it perfectly. Or as others have said, just get one from Markham.
SimS
/ Too short tooth bar #11
</font><font color="blue" class="small">( Alan;
SimS )</font>
That's what I did when I went from a 54" bucket to a 61" bucket. Actually fits the 61" bucket better then the 54" bucket it was originally made for.
However...in this case, I'd do what Bird suggests...just use a couple of spacers. To me, it isn't worth all the hassles for 3".
Once those spacers are fitted, I'd even consider welding them in place.
/ Too short tooth bar #12
The side bolts are just for keeping the toothbar on the bucket. I have been using mine with about an inch of spacers on either side for years now without any problem.
/ Too short tooth bar #13
If you have a oxygen-acetelyne setup you could just heat the attachment bars and make two slight bends one to get the bars close to the bucket the next bend to get them to sit flat against the side of the bucket.
Then drill your holes once its all lined up /forums/images/graemlins/smile.gif
/ Too short tooth bar #14
One slight issue to consider is that the bucket may not empty as cleanly.
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2022 EZ-GO ELITE...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
