too short pto shaft?
   / too short pto shaft? #1
gav64
Bronze Member
Eastern Connecticut
Mahindra 2810hst - Gehl 4625 skidsteer
my chipper pto shaft is too short to work with my speeco quick hitch. Can you safely lenghten the shaft, or can you use a spline extension like you would use for a pto pump or should i just go out and by and other shaft. thanks glenn
   / too short pto shaft? #2
I've seen folks legnthen PTO shafts. You CAN use an extention/adapter.
BUT. If it were me, I'd spring for a PTO shaft that's the correct legnth. They're not that expensive.
I'm a saftey fanatic. JMHO
   / too short pto shaft? #3
On most PTO shafts the tubes are replaceable by driving out the pin holding the tube to the yoke. Then you can replace with a new tube, reinstall the roll pin and then cut to length needed.
Lewis
   / too short pto shaft? #4
I measured to figure out how much longer I needed my tiller PTO shaft after installing a quick hitch. Took it to a drive line specialty place (for truck shafts).
They found me a drop off piece and cut it to length for me for $20. Buying a 4 ft stick at TSC would have been $50--if they had the size I needed, which they didn't.
If you take the whole thing, they can do it in a fraction of the time you or I can.
Ron
   / too short pto shaft? #5
That is cheaper than my idea of using a 1 3/8 to 1 1/16 adapter then a 1 1/16 to 1 3/8 adapter on that. The whole arrangement would run around $40, but the part are easier to find than an old shaft. /forums/images/graemlins/wink.gif
Case TV380 (A50123)
Case TV380 (A50123)
ALLISON TRANSMISSION (A53843)
ALLISON...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
Caterpillar Loader Quick Coupler (A53473)
Caterpillar Loader...
Electric Mobility Scooter (A51694)
Electric Mobility...
