Too Much Tractor?
/ Too Much Tractor? #42
As long as you don’t have to hire a lowboy to move it, it’s not too big.
/ Too Much Tractor? #43
If you are working with just one tractor the Mx5800 is about the right size, however I somewhat disagree with the above quote. I suggest you consider a second smaller "chore" tractor as it makes life much easier, but a larger M size machine seems the right size for your main machine.
I agree. A 2 tractor solution is perfect for many folks with larger acreage. The big tractor for big chores and a smaller B or L series size unit for chores around the house. The last 25 years I utilized a small tractor with a rear finish mower. Finally got a T4.75 New Holland and purchased a mower to keep the tractor off the grass. My little 1720 New Holland was IMHO the perfect size for mowing and doing stuff around the house.
/ Too Much Tractor? #44
"Why would he ask his wife? What are you three" No, he might just like getting in bed at night with something other than a bag of ice cubes.
So - you think the tractor you are ordering might be too big - - Call Tim the Tool Man and see what he has to say. rah, rah
/ Too Much Tractor? #46
The nice thing with the MX series is that you can widen it up for your steep hills. I had an L and power wise it was fine but the added weight and stability of the MX makes it perfect for our place.
/ Too Much Tractor? #47
According to Tractor Data, The L6060 weighs 3990 to 4365 pounds and the MX5800 weighs 3734 lbs; are these wrong?
/ Too Much Tractor? #49
He may mean the smaller L series like the 01's- under 3000 pounds
All the Grand Ls are pretty much the same weight. My cabbed L4060 is 5k with a loader & loaded rear tires. An economy L2501, L3301 or L3901 is about 3-3.5k lbs with a loader & loaded tires.
No clue how much the MXes are.
/ Too Much Tractor? #50
I imagine he was now that you mentioned it, that's what steered me away from them in my first ten minutes on the lot. I really liked the MX Series, but I have to have a cab. The MX looks more robust and the weights surprised me. I have fluid filled tires, but later added wheel weights.
/ Too Much Tractor? #51
Correct Cathy, Not a GRAND L, just a "normal" L3700SU - the weight was a good bit less and the width I could get out of the MX series really sold me on it. The L was just way to tippy on all our hills.
We moved to an L after owning a B - the L seemed "big" at the time but was a mistake for us. Nice tractor, just not good for our terrain. Good thing is when I sold it I lost VERY little. Cost of education at the time.
/ Too Much Tractor? #52
I have about 25 heavily wooded acres and a half-mile dirt/gravel driveway to maintain.
When considering a new tractor, I spent a lot of time doing research and reading this forum. I opted for the MX5800. I keep a grapple bucket on the front and a skidding winch on the rear most of the time (sometimes the skidding winch comes off in favor of a chipper). I also have a land grader for the driveway that I have yet to get dirty.
I've only had it a relatively short time, but so far I'm very happy with it. I'm already considering a second, smaller tractor to get more access in among the trees. I have a lot of debris down in there and the MX is just too big for driving in there. I'm considering a BX or a B for that task.
Even though it won't make it into the forest, I've learned that, generally, you can never have "too big" of a tractor. I'm also warming up to the thought that you can't have too many either!
/ Too Much Tractor? #53
Got to agree with that; some of ours.
/ Too Much Tractor? #54
I've got 42 acres of woods with 3 acres of homestead. I've settled on a L3301 HST because of maneuverability and tasks that won't require the need for large PTO hp. I rented a skid steer with brush cutter and got stuck in mud within 2 hrs.
FLATBED SEMI TRAILER (A61568)
FLATBED SEMI...
Dodge Charger (A61569)
Sterling 9500 (A63118)
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED KUBOTA BRUSH GUARD PARTS (A62130)
UNUSED KUBOTA...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
