Too much play in 2520 joystick
   / Too much play in 2520 joystick
Fastpauly,
No biggie, it's easy to get turned around looking at those schematics.
Have a good one!
   / Too much play in 2520 joystick #12
I have the same issue with my 2520 joystick - were you able to make the adjustment? Just curious how things worked out for you. Thanks, Brad
Brad,
Yes, I made the adjustment and it solved my problem. The amount of "play" wasn't reduced but I was able to get the joystick to engage the valve for the rollback function earlier, so it wasn't hitting my leg. You'll need to remove the nut holding the top of the tierod to the bracket it's attached to, then loosen the locknut that locks the tierod to the rest of the linkage. turn the tierod clockwise (to shorten the overall linkage assembly). I think I made 5 or 6 turns. You can just slide the tierod end back onto the bolt on the joystick bracket and test out the new position before tightening everything back up.
   / Too much play in 2520 joystick #14
Thanks - will give it a try. Appreciate you getting back to me so quickly.
Cheers,
Brad
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54756)
DIXIE CHOPPER...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2003 Freightliner ambulance (A55788)
2003 Freightliner...
White Loader (A50775)
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
