Too much play in 2520 joystick
   / Too much play in 2520 joystick
Fastpauly,
No biggie, it's easy to get turned around looking at those schematics.
Have a good one!
   / Too much play in 2520 joystick #12
I have the same issue with my 2520 joystick - were you able to make the adjustment? Just curious how things worked out for you. Thanks, Brad
Brad,
Yes, I made the adjustment and it solved my problem. The amount of "play" wasn't reduced but I was able to get the joystick to engage the valve for the rollback function earlier, so it wasn't hitting my leg. You'll need to remove the nut holding the top of the tierod to the bracket it's attached to, then loosen the locknut that locks the tierod to the rest of the linkage. turn the tierod clockwise (to shorten the overall linkage assembly). I think I made 5 or 6 turns. You can just slide the tierod end back onto the bolt on the joystick bracket and test out the new position before tightening everything back up.
   / Too much play in 2520 joystick #14
Thanks - will give it a try. Appreciate you getting back to me so quickly.
Cheers,
Brad
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2013 Fiat 500 Hatchbacks (A55758)
2013 Fiat 500...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2013 Ford E350 Box Truck (A47477)
2013 Ford E350 Box...
