too much hydraulic fluid ? L 3800 kabota
   / too much hydraulic fluid ? L 3800 kabota #1
jeffro31
kabota L3800 w/bh77
i had a hydraulic hose burst and it is the one going to my back hoe. and fluid was lost. i disconected my back hoe and was putting hydraulic fluid back into the tractor and i put too much how do i get it out? and where is the screw to let it out?L 3800 kabota 4wd.
   / too much hydraulic fluid ? L 3800 kabota #2
jeffro, I just serviced my L3400 and when refilling the hydro, I put in 6 gallons, checked the sight glass and didn't see anything, so I added another gallon, still nothing, so I added one more. I know, stupid me, it only holds 6, but I had added a grapple, 4 remotes and TNT, and I figured... anyway, I had to get 2 gallons out, so I took one of the hoses loose from the top link cylinder, started the engine and s-l-o-w-l-y pulled the valve lever until fluid started coming out. It worked fine. It was not nearly as scary as I thought it would be. You may be able to do that with one of your back hoe hoses, just be careful go slow until you get the feel of it.
   / too much hydraulic fluid ? L 3800 kabota #3
Just put one of the BH hoses in a bucket and activate the lever for that cyl.
   / too much hydraulic fluid ? L 3800 kabota #4
I just overfilled my L3400 and just dropped the bottom plug and drained into a clean pan. Your hand gets a little oily getting the plug back in mid-stream but nothing to difficult.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
Electric Mobility Scooter (A51694)
Electric Mobility...
