Tomato supports?
   / Tomato supports? #1
framer
Central Kansas
B7800
Has any one tried 4 foot fence as trellis for tomatoes or some thing better than flimsy gages.Thanks
   / Tomato supports? #2
Haven't tried a fence, I use rebar. Bought 20 ft. lengths & cut them in 3 pieces. I use a post driver with the two handles on the sides that I made to drive them in. The ribs on the rebar holds the twine that I use to tie the plants.
   / Tomato supports? #3
Two rows of page wire fencing set about a foot apart. posts were 12 feet apart, wire stretched tight. Worked like a charm
   / Tomato supports? #4
round cages made out of heavy 6x6 welded wire.
holes are big enough to reach in and pick the tomatoes, but it's still sturdy enough to handle a pretty full bush.
   / Tomato supports? #6
Ditto on the heavy welded wire - they'll last for years. Stake them into the ground, usually only one point is necessary.
Mike
   / Tomato supports? #7
I'm in the process of making my own cages right now. Using 1/4" round cold rolled. Slight overkill maybe, but should last for years.
Mark
   / Tomato supports? #8
   / Tomato supports? #9
I do hang upside down...has work well over the years.
   / Tomato supports? #10
The best ones I ever used were ones I made from concrete reinforcing wire.
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
TMA (A49461)
TMA (A49461)
