Tomato supports?
   / Tomato supports? #1
framer
Central Kansas
B7800
Has any one tried 4 foot fence as trellis for tomatoes or some thing better than flimsy gages.Thanks
   / Tomato supports? #2
Haven't tried a fence, I use rebar. Bought 20 ft. lengths & cut them in 3 pieces. I use a post driver with the two handles on the sides that I made to drive them in. The ribs on the rebar holds the twine that I use to tie the plants.
   / Tomato supports? #3
Two rows of page wire fencing set about a foot apart. posts were 12 feet apart, wire stretched tight. Worked like a charm
   / Tomato supports? #4
round cages made out of heavy 6x6 welded wire.
holes are big enough to reach in and pick the tomatoes, but it's still sturdy enough to handle a pretty full bush.
   / Tomato supports? #6
Ditto on the heavy welded wire - they'll last for years. Stake them into the ground, usually only one point is necessary.
Mike
   / Tomato supports? #7
I'm in the process of making my own cages right now. Using 1/4" round cold rolled. Slight overkill maybe, but should last for years.
Mark
   / Tomato supports? #8
   / Tomato supports? #9
I do hang upside down...has work well over the years.
   / Tomato supports? #10
The best ones I ever used were ones I made from concrete reinforcing wire.
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
