TODAYS SEAT TIME
/ TODAYS SEAT TIME #14,062
I'm sanding almost a quarter of a mile, doing a light sanding with the gas engine throttled down for a narrow pattern one load will do a decent job. If it's a lot of ice from an ice storm (1/4" or so) I may use a load and half.
The sander holds well over a yard and a half of sand when loaded with a heaping load, with "damp" sand being over 3000 pounds per yard it can be a pain pulling a trailer down or up hill.
With an 11,000# tractor with chains on all four it's not an issue but you sure know it's behind you on hills.
On a chained up truck it was a piece of cake, on the trailer it can get your attention.
This is my third sander, I've rebuilt 2 older steel body sanders. Then I bought this new SS sander 10-12 years ago. I see that there are some smaller 3 point self loading sander available now days.
If I am reading what you you saying right with my 7500 lb tractor chained up on all four with euro ice chains and hard ice on a hilly road about a yard of sand would be all I could do - if that ????
gg
/ TODAYS SEAT TIME #14,063
gg
My driveway is 14-16 degrees or 25+% slope so with a full sander of 1 1/2 yds or around 4500# of sand plus the trailer is a heavy trailer and the sander it's self it can be over 7000# behind you and pushing.
I am well aware of that load behind my Branson 8050 which is over 11,000 pounds also on chains. I've never had it get away from me or get me sideways but it does get my attention at times.
I would recommend small loads at first to see how it felt on the hills. It would also make a considerable difference with how much tongue weight is loaded onto the tractor.
/ TODAYS SEAT TIME #14,064
Put an hour on the tractor today clearing up the snowstorm. Had to replace the Trex board cutting edge I had on the bucket. Made it 2.5 winters, not bad for $8.
/ TODAYS SEAT TIME #14,065
It was touch and go for a bit there. But I made it to the end of the driveway. :whistle:
/ TODAYS SEAT TIME #14,071
Today I used my pallet forks to straighten fence posts (that were pushed over by horses leaning on them). The technique is:
1.) Drive up to the post with the end of one of the forks about 2/3 up from the bottom of the post.
2.) Drive forward enough to push the post past vertical a little.
3.) Back up slightly, and raise the forks above the top of the post.
4.) Drive forward, centering the top of the post under one fork and, with the forks tilted up slightly, start lowering the fork down on top of the post and push it down into the ground enough that it stands up straight.
5.) Repeat, ad-infinitum.
Next task was to move some errant railroad ties.
/ TODAYS SEAT TIME #14,072
View attachment 4705303View attachment 4705307View attachment 4705342Next task was to move some errant railroad ties.
I just straighten mine by hand. They bend pretty easily
/ TODAYS SEAT TIME #14,075
We had a few inches here, nothing to write home about. I decided that it was time to swap the grapple for my bucket... it's been so long since I took it off that I had to look around a bit to find it!
Another reason to keep things inside; it lessens the area you can lose it in!
/ TODAYS SEAT TIME #14,076
But you can often bury deep under other treasures in the shop. :rolleyes:
/ TODAYS SEAT TIME #14,077
Got the parts container vacuumed out and moved to hiding alley. Put the generator in back of the truck also. This tractor makes me want one for the house in the city 😂
/ TODAYS SEAT TIME #14,078
Got the parts container vacuumed out and moved to hiding alley. Put the generator in back of the truck also. This tractor makes me want one for the house in the city 😂View attachment 4823766
That is an unusual 3-point attachment you have there. What does it do?
JMR 4X8 Basket for skid steer or pallet fork (A61567)
JMR 4X8 Basket for...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2017 WILSON DWH-600 4X2 T/A 41FT HOPPER TRAILER (A59906)
2017 WILSON...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
