TODAYS SEAT TIME
   / TODAYS SEAT TIME #8,611
Cool, I've had the same hitchhikers this year.
I believe they think I'm the local Uber driver...;)
I don't mind them on the hood, when the big ones jump on my legs, ugh
   / TODAYS SEAT TIME #8,612
There're here...... I picked up the EA box blade and grapple yesterday and tried them out today. Went on easy and looks great. Tried the box blade first and realized in 2 minutes how important a hydraulic top link will be. Learning curve for sure especially with very rocky soil. After an hour figured the grapple would be better for rocks than the std bucket with a piranha tooth bar. Got it on, greased it and then hit the WR Long third function toggle and Nothing. After a couple of hours found the culprit and changed the 2 amp inline fuse. Hit the switch, got the lids open 1/2 way and it blew again. Any ideas? Is 2 amp correct?
Switch grapple to Express Steel 7/8 yd 66" material bucket and scaped 40+yds of rocks and soil and moved it. I like this bucket better than factory; good thing with all the material I have to move.
   / TODAYS SEAT TIME #8,613
View attachment 566945View attachment 566946
That’s a nice grapple! Be sure and set you up a good counterweight to get the most out of it. And yes, a hydraulic top link is on top of the list.
As far as the fuse size - do you have an amp meter you can check the solenoids with? I have a three way valve on my 3rd function - I don’t recall the fuse size. I can look tomorrow and let you know. I wouldn’t think the solenoids would draw much. Have you checked the circuit with your ohm meter to make sure it’s not grounding out when you hit the switch?
   / TODAYS SEAT TIME #8,614
Spend a long time on the JD 455 (21hp diesel) mower cutting grass lol. I cut my acre and half of grass, cut the pasture for the first time in two years, had to cut it twice (1 acre). Cut the back 1/2 acre of a elderly neighbors property that’s back in the woods on a hill.
The other neighbor has had their mower sitting outside in front of their house for a few weeks now so I cut their front and most of their rear, I didn’t cut up near their house but I cut at least an acre of their grass, I would guess an acre and half of their 2 acres
I spent a good 5 hours on the mower and burned up 3/4 a tank which is a lot for a diesel mower. Drove the mower down the road to the gas station, dumped 5.5 gallons in the tank, drove it home and parked it in the garage.
JD 455 with Oregon G6 blades, the lawn looked like a golf course, the pasture looked like a lawn lol. IMG_9990.JPG
   / TODAYS SEAT TIME #8,615
Traded for a JD3720 a couple months back. I have put 56 hours on the machine. Doing mostly bushwhacking and clearing out trees that were pushed over for a log road. The log road is now becoming my Drive for a home soon. Anywho, put on the box blade for some final cleanup..pushing small brush piles into a bigger pile... you get the picture. Inevitably you get used to a piece of equipment and you get complacent.....IMG_0906.JPGIMG_0904.JPG
   / TODAYS SEAT TIME #8,616
In my defense the root was hidden by all that dirt and stuff. :rolleyes: Anyone know where a fella could get a used Draft Arm? They want 400 dollars for a new one. :shocked:
   / TODAYS SEAT TIME #8,617
Ouch! My Wife's uncle has a 3720. Think he'd miss one arm? :cool:
   / TODAYS SEAT TIME #8,618
A bit of heat and a sledge hammer, if it hasn't cracked.
   / TODAYS SEAT TIME #8,619
If he won't miss it I will trade you some money for a dirty old piece of steel...:thumbsup:
   / TODAYS SEAT TIME #8,620
That looks bendable back into shape and I've straightened worse. Some heat, a heavy, flat faced hammer and an anvil is all you need.
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
