Today, would you buy an EV vehicle.
Status
Not open for further replies.
   / Today, would you buy an EV vehicle. #51
I didn't think that his comment deserved a response. We are fortunate enough to be tied into the Canadian grid, which is much more reliable than what most of our state has to put up with. Some would like to change that, as they feel that "We should all be in the New England network."
I guess my local electrical co-op is better than most. The only time my power goes out is from a hurricane or the rare snow/ice storm.
When I run my welder or turn down the ac I don't worry about the grid. When someone buys a farm and builds 19 new bigger than most houses they're not worried about the grid. So I find it funny that when evs are mentioned everyone becomes the grids parent and starts worrying.
   / Today, would you buy an EV vehicle. #52
Just across the line in NC people like to burn plastic/Styrofoam/trash/tires because they don't have city trash pick up. Does that mean I should do the same?
No one is saying we shouldn't leave this earth better than we found it but why should we cripple our economy while China and India doesn't have to live within the same standards.
   / Today, would you buy an EV vehicle. #53
You gotta find that balance.
   / Today, would you buy an EV vehicle. #54
No longer offered in the US, of course. For $20k though, I would want more than a 60 mile range. It might be nice in Boston or DC, but if I lived in those towns I probably would ride the bus.
Correction; if I lived in one of those towns I'd move.
See several on the road and one about 20 minutes ago with 4 adults.
   / Today, would you buy an EV vehicle. #55
The politicians pushing (or mandating) electric vehicles have no concept of cause and effect. When you add a huge electric demand to the grid without first adding the capacity to grid to handle this huge load, the effect will be long power outages and brownouts.
Buy your standby generators to keep your freezers going now if you don't already have one.
Old transformers are failing where the number of electric cars are popular...
Cause and effect or just coincidence?
   / Today, would you buy an EV vehicle. #56
Charging battery-powered vehicles is a very large load on everything from the meter on back to the power plant that the system is not currently designed for. It is not only a large amount of energy that is drawn in total, but it is a high amperage sustained load. Residential utility supplies are designed for intermittent, sporadic loading such as an A/C kicking on and drawing several hundred amps for a second, 30 amps for 10 minutes, and then being off for a half an hour. They are massively under-specified for continuous loading.
If you want an example, if you have an overhead service drop, look at how much smaller the wires going from the transformer overhead to the service drop compared to the much fatter wires they are spliced to just in front of the weatherhead. Common is 4/0 aluminum on your side spliced to 1 AWG aluminum on their side. The NEC requires you to size for an 80% continuous load, the utility sizes for closer to a 30-40% load.
Also look at the transformers. A large residential transformer is 25 kVA, typically used for houses with more than one 200 amp panel or in cities, this is often shared between several houses. This transformer can supply 104 amps at 240 volts on a sustained basis. (Note that these are connected to generally a couple of 200 amp panels in a house, not one 100 amp panel, and that a house with two 200 amp panels doesn't have a 100 kVA transformer to sustain 400 amps.) A more typical single-family residential transformer is 10 or 15 kVA with one per house, in a house with a single 100/150/200 amp panel. 10 kVA is 41.6 amps and 15 kVA is 62.5 amps continuously. Vehicle battery chargers vary, but a typical 240 volt "level 2" home charger will draw 30-40 amps and some Tesla home chargers can draw up to 80 amps, all of this continuously for hours until the car is charged. Somebody with one non-Tesla battery-powered vehicle in a larger house with a 25 kVA transformer would be fine as they probably don't draw more than about 15 kVA excepting the battery charger, even with the A/Cs running. Adding 9.6 kVA for a 40 amp charger won't kill that transformer. Adding two of them, maybe, after a while, if you aren't careful and don't charge both at once when the A/C, stove, etc. are on. Adding a sustained 9.6 kVA load for hours to whatever else the house is using already to a 10 kVA transformer will destroy it in fairly short order. Having three people living in a city on a shared 25 kVA transformer each charging a Tesla at the same time would draw 56 kVA plus whatever they A/C and dryers and such are drawing, and that transformer will die quickly.
Now realize the rest of the grid is designed similarly, it has enough capacity for some amount over previous peak usage, but not enough for a bunch of people to double or triple their previous amperage draws at their houses for hours at a time. Big continuous loads used to be the domain of commercial/industrial 3 phase customers, and all of these installations at least anywhere I've ever been had to have a utility engineer review the load and its timing, and ensure everything from the substation on out to the transformer(s) could handle the load. If you were going to draw a lot of power and they needed to upgrade lines, switching equipment, substation, etc. for your usage you generally had some skin in that game.
We can certainly upgrade he transmission lines, substations, distribution lines, and customer transformers to handle the load of charging battery-powered vehicles. It just costs money. Upgrading generation capacity, however, is a much thornier issue and money alone won't solve it.
   / Today, would you buy an EV vehicle. #57
We have one huge oil refinery in Minnesota. It has applied for a huge solar grid to supply power for their refinery because using the fuel delivered to their plant is too expensive. If a refinery can’t afford oil for power generation and is going solar, why would fossil fuel be cheaper for vehicles? I don’t know the answer but seeing them apply for a 120 acre solar panel seemed surprising as they should be paying less for their oil than any of us. Me, I’d like a Lightning and have a work power source with me. But I won’t be getting one soon.
   / Today, would you buy an EV vehicle. #58
Here is a trucking link about the total phase out of drayage trucks entering ports and rail yards...
   / Today, would you buy an EV vehicle. #59
Some years back, a very large smelting operation shut down. As I recall, it was said that the one plant used more power than all of the residential customers combined. The loss was large enough that they somehow convinced (conned?) the PSC into allowing them to raise rates for everyone else.
That generating capacity is still there and may have even been increased.
You'll have similar situations across the country where larger, high use industrial plants are either shutting down or converting operations.
That doesn't necessarily mean that the transmission lines to each home are sufficient.
   / Today, would you buy an EV vehicle. #60
I see first hand (because of where I work) the resources being devoted to EVs, it's going to happen and if you want to purchase a vehicle, you'll have to purchase what ever it is the companies are selling. Eventually, through legislation, penalties, etc., ICEs will be forced off the road. ICEs have had a good run, over 100 years isn't bad, maybe it's time for a change. Henry Ford had said "If I had asked what people they wanted, they would have said faster horses." I'm sure there were people back then that said similar things to what's being said today about EVs and how many people would prefer that we go back to riding horses?
Status
2025 78in Rock Bucket Skid Steer Attachment (A55787)
2025 78in Rock...
2013 Cadillac Srx (A55853)
2013 Cadillac Srx...
2016 Isuzu NRR 1,200 Gallon Fuel Transport Truck (A55788)
2016 Isuzu NRR...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2014 BMW (A55758)
2014 BMW (A55758)
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A55788)
2011 Mack GU713...
