TO30 Points/Condenser
/ TO30 Points/Condenser #11
Try putting the old condenser back in, these new ones are hit or miss on quality and can short out your spark. Point gap on this engine is .020, make sure your setting it with the points high on the lobe and use point lube on the rubbing block.
/ TO30 Points/Condenser #12
I’d think there’d be some way to use a dwell meter also to get an exact setting. Same with a timing light.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2013 Ford F-450 Service Truck (A59230)
2013 Ford F-450...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
2004 Toyota Camry Solara Coupe (A59231)
2004 Toyota Camry...
