To20 axle seals replacment
   / To20 axle seals replacment #1
sgblazer2
massey 135
i am thinking about purchasing a massey to20 from a local guy and he is telling me that the axles seals need to be replaced, because they are leaking onto the brakes and causing it to brake poorly. it seems pretty straight foward to me, unbolt the hub assembly and remove the axle (similar to a ford 9"), press off bearing and replace seals, but a friend of mine said there may be shims on the inside of the case and they may fall when removing the axle. is this true or is it pretty straight foward?
thanks for any help, for this is going to be my first tractor
   / To20 axle seals replacment #2
It's an easy job. The inner seal is usually the one leaking though.. no need to press off a bearing in that case. But the brake shoes will be toast and must be replaced. the axle housing seal is cheap, the brakes are not.
glad to hear its a easy fix! i priced shoes on ebay and they are around $65, is that a goo price?
   / To20 axle seals replacment #4
No, go to the yesterday's tractor site. I think they're 55.00 and the shipping is cheap. they have the seals too
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
Ex Mark Zero Turn Mower (A51573)
Ex Mark Zero Turn...
City of Lakeland (A51691)
City of Lakeland...
