To20 axle seals replacment
/ To20 axle seals replacment #1
sgblazer2
massey 135
i am thinking about purchasing a massey to20 from a local guy and he is telling me that the axles seals need to be replaced, because they are leaking onto the brakes and causing it to brake poorly. it seems pretty straight foward to me, unbolt the hub assembly and remove the axle (similar to a ford 9"), press off bearing and replace seals, but a friend of mine said there may be shims on the inside of the case and they may fall when removing the axle. is this true or is it pretty straight foward?
thanks for any help, for this is going to be my first tractor
/ To20 axle seals replacment #2
It's an easy job. The inner seal is usually the one leaking though.. no need to press off a bearing in that case. But the brake shoes will be toast and must be replaced. the axle housing seal is cheap, the brakes are not.
glad to hear its a easy fix! i priced shoes on ebay and they are around $65, is that a goo price?
/ To20 axle seals replacment #4
No, go to the yesterday's tractor site. I think they're 55.00 and the shipping is cheap. they have the seals too
2022 GEHL RT215 SKID STEER (A65053)
2022 GEHL RT215...
2019 Dodge Charger SRT Sedan (A64557)
2019 Dodge Charger...
UNUSED JCT 72" HYD HEAVY DUTY BRUSHCUTTER (A65055)
UNUSED JCT 72" HYD...
UNVERFERTH GW-530 GRAVITY WAGON (A64278)
UNVERFERTH GW-530...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
