Ballast To use or not to use - front weights
   / To use or not to use - front weights #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Time to start thinking about snow removal. I use a 6' rear blade on my Kubota 7500hst, 400' gravel drive. I know you're not supposed to use rear R4's and front turfs while in 4wd because of potential transmission damage. Here are some questions I have:
1 - Using turf tires with rear chains, could I or should I use front weights?
2 - Would you use 4wd while using rear wheel chains only?
   / To use or not to use - front weights #2
CHRIS: your are in my neck of the woods,have u used this tractor before to move snow? seems like 400ft is a long way with rear blade, especially with deep snow. iwould most certainly use some kind of front weights.
   / To use or not to use - front weights #3
I run turf tires all the way around w/chains on the rear,and yet to have any problems during all four seasons.
Just keep the chains tight and take your time.
I have used a riding lawn mower with a 4' blade and also a blower. Using a blade caused the driveway to get narrower and the snow banks higher with each pass.
The blower was great but it got beat up pretty bad eating small rocks.
I would get angry with both because the rider was not big enough to handle the amount of snow or the large driveway.
I'm figuring the first real snow will be here less than a month.
   / To use or not to use - front weights #5
if it can be arranged in your budget, why not consider a fel, will help u keep the banks pushed back. or mabey a rear blower?
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
