Oil & Fuel To use additives or not?
/ To use additives or not? #21
For what it is worth: My dealer's service manager had a discussion with the regional Mahindra rep and they suggested that all of the Tier IV models use an additive. My dealer gave me the first bottle of Power Service and told me to follow the suggestions on the bottle year round. So that is what I'm dong.
That's good to know. I have it covered. Now if only the tractor would get here I have the stuff for it.
/ To use additives or not? #23
Would that dealer be Burnips? I just bought a Max 26XL with MMM, BH, and FEL from them. so far it has been a very good experience. So I guess I should be putting that stuff in my tank?
/ To use additives or not? #24
Great info on the additives. I have tried a few different ones, everyone says theirs are the best. Has anyone tried Lucas? According to the fuel supplier I talked to which happened to be BP. Said it is not needed for lubrication. Not sure if I agree. I don't use the off road fuel as its not really any cheaper where I am. I was told it was all the same just dyed nowadays. I don't use enough fuel to make saving a few cents per gallon that big of a deal. I'm not opposed to using a fuel additives but it may be years before you know if it really helped if ever. It's really not about the money it more about the benefits. Could any chemist chime in and shed some light on this?
/ To use additives or not? #26
People who add potions, lotions and elixirs to equipment. They tend to be the superstitious type of people that also believe in signs, omens, good luck charms , black cats, ladders, vitamins, copper and magnetic wrist bands etc.
/ To use additives or not? #27
You should really read that link I posted
/ To use additives or not? #28
Read some of the linked test,- did I read it correctly - #1 was by just adding some soy bio-diesel??
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
If so- wish we had a bio diesel station close...
Well a little search shows that one of the local diesel providers -Is gearing up to sell bio-diesel by the end of summer.:thumbsup:
/ To use additives or not? #30
We have started to use lucas this winter in our 7.3. Get it from tractor supply but lucky if it is in Stock usually buy the last bottle. Truck wouldn't start cause of fuel gelled. Put it in and in less then 5 min the truck fired right up. It even helped quiet the injectors right down
/ To use additives or not? #31
Each to his own, I have not used any additive to my fuel in 6 years. No anti-gel, no supposedly friction reduces or cetane boosters, no algaecide, nothing. Of course it never gets below 15F here (coldest I have seen it in 2014)and even then, neither me nor my brother in law have not had any issues with fuel or fuel components. I just keep my fuel tank inside my boat shed that is totally enclosed, but my brother in law just has his stuck under an open on 2 sides shed and hasn't even changed his bulk fuel tank filter in 6 years either. We also use what ever fuel that is brought when our tanks are empty year round whether it is winter or summer blend(don't know if they actually sell a winter blend here).
Much of the additives are snake oil and folks who use them can honestly say that they haven't had any problems, but it is hard to prove that you wouldn't have any problems by not using them either. With the exception of an anti-gel agent for you folks that get -49F temps, then most of the other stuff is really not needed for a modern engine that is designed to run on ultra low sulfur fuel.
If you are exposing your storage container to hot and cold fluctuations that may cause condensation to cause water in your tank, then an algaecide would be a good preventative measure also. I personally don't have any issue with water so I don't need that chemical which is a good thing because I have not seen any thing on automotive supply house shelves saying algaecide for diesel.
/ To use additives or not? #32
My feeling is that if you live in a place where it doesn't get frigid, then an additive is probably optional, but I'm real glad I use it as -9 F winters can raise heck with diesel gelling. It got that cold here this past winter an I had zero issues.. I'm not sure that would have been the case without it.
/ To use additives or not? #34
I've heard of people still having issues with that.
/ To use additives or not? #35
If lubrication of the diesel fuel itself is a concern, just add TCW-3 ash less two stroke oil for outboard water craft engines at a ratio anywhere between a 100 to 200:1. It will quiet the injectors down too.
Our furnace oil isn't quite the same here in N.S. as it is in Maine. With furnace oil here, the tractor will smoke more and the injectors are louder. So I add the cheapest TCW3 two stroke oil I can find (Walyword).
BY the time I add PowerService and the TCW3 stuff, I can almost buy normal diesel fuel.
As more soot you are blowing out of the pipe, as faster you need to change the engine oil. So I never run straight furnace oil in the winter. My cheap Canadian 2 cents worth...
/ To use additives or not? #36
They tested 2 stroke oil in the article, there was question of whether it would have done better with a lower mix ratio ( --/1) than what was used.
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
AGRI-CRAFT STAINLESS STEEL FERTILIZER TENDER (A63291)
AGRI-CRAFT...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
