Tires To load or not to load tires
   / To load or not to load tires #41
Sooo...... I have a couple ??. Does foam add much weight or is it mainly to prevent flats. I've heard that foam filled tires are a PITA when it comes time to install new tires - true?
Foam is heavy. Definitely used to add weight.
I've heard that it needs to be cut off the rim, but I have no firsthand experience
I would be interested to see someone hook a tractor to a sled with diff ballast and see which one pulls harder.
I read that weight on the axle gives a larger foot print by squatting the tire more vs a liquid ballast that more equally dissipates the weight and with air pressure doesn't squat as much so the tire digs more and has less traction.
Also I read that the industry standard of 75% full isn't as efficient as a 40% filled tire.
Using liquid ballast in tires
Also I have a titan R4 tire, I don't think it's a radial but I read that radials should not have liquid ballast in them.
   / To load or not to load tires #43
750lbs of external cast iron weight bolted onto the wheel will pull more than 750lbs of liquid ballast in the tire. All other factors identical.
2016 Ford Expedition SUV (A55853)
2016 Ford...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
WOLVERINE TF-4-66-5500 G PIN ON PALLET FORKS (A57192)
WOLVERINE...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2014 JOHN DEERE 672G MOTOR GRADER (A52707)
2014 JOHN DEERE...
