MapleLeafFarmer
Platinum Member
- Joined
- Jun 20, 2011
- Messages
- 734
- Location
- Canada
- Tractor
- lots including Kubota B's, L's, cat, etc.. over many years
are you sure?Unfortunately there is no real way to fix the slope. It is a flat swampy area. I will eventually put a culvert back behind the camera location that should stop the small trickle of water constantly moving through the mud hole. But rain and flood water will still fill the mud hole. I MIGHT be able to eek out a little better flow out the side with that water, but it it pretty darn flat in there. But if I fill the majority of the area it should facilitate drainage as the water has nowhere else to go but out the side.
couldn't you excavate a low area (think small pond) on one side, use the removed material to raise the road, add ditches both side, tile/culvert underneath to drain water to new low area?
cheap to do just really your labour
if you cann't relocate the water than you are left with fill/fill/fill till you get grade above the plain.
good luck... maybe its something you will just have to live with if investment in time/labour more than its worth to you. I have drained bogs 10's of acres in size to get trucks through an area - your spot looks pretty easy to make a solution.
cheers!
