To cold to grease!!
/ To cold to grease!! #1
Kubota-monkey
Massachusetts USA
L35 with bt900 backoe and box scraper + grader blade
I went outside tonight to grease the tractor. Pulled out the trusty grease gun, place the end around the grease nipple and tried to pump grease into it and t ono avail. I tried with all my might but not one once of grease seeped into the joint.. ANy suggestions?
The Ben from MA /w3tcompact/icons/cool.gif
/ To cold to grease!! #2
KM,
Was your grease gun stored where it was warm,also try parking your tractor in the sun to warm for greasing.
I heard of tractor owners useing a small propane torch to lightly warm up the area for greasing..
During the cold weather months I grease my tractors after done useing them..seem to work better.
Take care an have a pleasant day.
Thomas..NH /w3tcompact/icons/wink.gif
/ To cold to grease!! #3
I have to keep my grease gun in a heated basement and also wait for a fairly warm day to grease the tractor or the same thing happens.
/ To cold to grease!! #4
In the most recent "Fine Homebuilding". Someone submitted a "tip and trick" for cold weather caulking. It used those disposable hand / foot warmer packs with a pipe insulation sock. I doubt that it would warm up a grease gun that had been kept in the cold but it might keep the grease warm for an afternoon of winter tractor maintainence.
/ To cold to grease!! #5
rock,
Never heard of trying that./w3tcompact/icons/shocked.gif
I do have a pair of 9v battery socks...I wonder /w3tcompact/icons/blush.gif..naaa.. /w3tcompact/icons/smile.gif
/ To cold to grease!! #6
Would a synthetic grease be more effective in those sub zero temps? I wonder if the check valves in the grease nipples are frozen with ice. The lid hinge on my truck toolbox hasn't thawed since last weeks' freezing rain./w3tcompact/icons/frown.gif
Yes Thomas, my grease gun was stored in a place warm. The grease came out fine when I didnt stick it on the nipple. I think I will purchase a propane burner to heat up the nipple before greasing, maybe that will get rid of the ice.
/ To cold to grease!! #8
Kubota-monkey, just for grins had use that ol' torch trick to thaw out the frozen padlocks on my cargo trailer this weekend. /w3tcompact/icons/smile.gif
/ To cold to grease!! #9
Kubota-monkey,
That should work,but don't forget your still pushing cold grease in the lines which means more pressure..be careful.
Better diesel & grease up we got a storm coming,and if this holds true you folks down there are going to get a mix bag...yikes. /w3tcompact/icons/shocked.gif/w3tcompact/icons/crazy.gif
Be careful if we don't hear from you!!
Thanks for the info Thomas... Although now they are calling for 2 feet!!!!! on Sat night!
/ To cold to grease!! #11
Kubota-monkey,
Yep looks like you folks down there are going to get the blunt of the storm for sure. /w3tcompact/icons/shocked.gif
The weather station saying we should get around 6 inches,but like DFB said "yeah right" and I'm not putting all my eggs in one basket./w3tcompact/icons/wink.gif
Better diesel up and plug her in,you got some seat time coming. /w3tcompact/icons/smile.gif
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
JOHN DEERE 323E SKID STEER (A64279)
JOHN DEERE 323E...
Caterpillar Traxcavator parts books (A63117)
Caterpillar...
CATERPILLAR 573D FELLER BUNCHER (A64276)
CATERPILLAR 573D...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
