To cold to grease!!
/ To cold to grease!! #1
Kubota-monkey
Massachusetts USA
L35 with bt900 backoe and box scraper + grader blade
I went outside tonight to grease the tractor. Pulled out the trusty grease gun, place the end around the grease nipple and tried to pump grease into it and t ono avail. I tried with all my might but not one once of grease seeped into the joint.. ANy suggestions?
The Ben from MA /w3tcompact/icons/cool.gif
/ To cold to grease!! #2
KM,
Was your grease gun stored where it was warm,also try parking your tractor in the sun to warm for greasing.
I heard of tractor owners useing a small propane torch to lightly warm up the area for greasing..
During the cold weather months I grease my tractors after done useing them..seem to work better.
Take care an have a pleasant day.
Thomas..NH /w3tcompact/icons/wink.gif
/ To cold to grease!! #3
I have to keep my grease gun in a heated basement and also wait for a fairly warm day to grease the tractor or the same thing happens.
/ To cold to grease!! #4
In the most recent "Fine Homebuilding". Someone submitted a "tip and trick" for cold weather caulking. It used those disposable hand / foot warmer packs with a pipe insulation sock. I doubt that it would warm up a grease gun that had been kept in the cold but it might keep the grease warm for an afternoon of winter tractor maintainence.
/ To cold to grease!! #5
rock,
Never heard of trying that./w3tcompact/icons/shocked.gif
I do have a pair of 9v battery socks...I wonder /w3tcompact/icons/blush.gif..naaa.. /w3tcompact/icons/smile.gif
/ To cold to grease!! #6
Would a synthetic grease be more effective in those sub zero temps? I wonder if the check valves in the grease nipples are frozen with ice. The lid hinge on my truck toolbox hasn't thawed since last weeks' freezing rain./w3tcompact/icons/frown.gif
Yes Thomas, my grease gun was stored in a place warm. The grease came out fine when I didnt stick it on the nipple. I think I will purchase a propane burner to heat up the nipple before greasing, maybe that will get rid of the ice.
/ To cold to grease!! #8
Kubota-monkey, just for grins had use that ol' torch trick to thaw out the frozen padlocks on my cargo trailer this weekend. /w3tcompact/icons/smile.gif
/ To cold to grease!! #9
Kubota-monkey,
That should work,but don't forget your still pushing cold grease in the lines which means more pressure..be careful.
Better diesel & grease up we got a storm coming,and if this holds true you folks down there are going to get a mix bag...yikes. /w3tcompact/icons/shocked.gif/w3tcompact/icons/crazy.gif
Be careful if we don't hear from you!!
Thanks for the info Thomas... Although now they are calling for 2 feet!!!!! on Sat night!
/ To cold to grease!! #11
Kubota-monkey,
Yep looks like you folks down there are going to get the blunt of the storm for sure. /w3tcompact/icons/shocked.gif
The weather station saying we should get around 6 inches,but like DFB said "yeah right" and I'm not putting all my eggs in one basket./w3tcompact/icons/wink.gif
Better diesel up and plug her in,you got some seat time coming. /w3tcompact/icons/smile.gif
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2019 CHEVROLET TAHOE (A62130)
2019 CHEVROLET...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
10,000 PSI AIR HYDRAULIC PUMP (A60736)
10,000 PSI AIR...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
