To Buy or to Rent?
   / To Buy or to Rent? #11
I used to think the same way. A year later I added the backhoe. Now , without reservation, I WILL admit, I was wrong. It's a lifesaver.
   / To Buy or to Rent? #12
So much depends on what a person's needs are. If you need to do a lot of 3PH work, it can be a PITA to deal with a backhoe. On smaller tractors, the BH can limit what you can do.
I have done less than $700 of BH work in the last 9 years so a BH is not a sensible investment for my needs.
I can see it as essential for others.
   / To Buy or to Rent? #13
As others have said, it depends on your needs/use. I was talked out of a BH by this forum buying my NX6010. It was the right decision. But an also "right" decision for me was buying a smaller, used JD a few years ago with a hoe on it. I use it all the time, it's a smaller tractor so useful for moving things around using the FEL, but most of the use is the hoe. If I had to put the hoe on/off every time, I'd use it 1/2 as much. It's so convenient though, just walk up to the barn, fire up the tractor, drive it where I need a hole, dig, put it back.
I've rented a mini-ex as well for bigger tasks, and it's a wonderful machine, but about 4X the price about 1/2 as flexible as my little 2720. Also digs about 8X as fast. :)
I live where we have red clay as our "dirt". Digging a hole for a 3 gallon tree without a hoe is back breaking. Doing 10 in a day would be a trip to the hospital. I use the hoe all the time to pull out and put in trees, it's incredibly useful.
And, laughably, the tractor with the hoe is worth more today than when I bought it. I did have to put around 2K into it over the past 5 years in maintenance, but I'm still money ahead. And I have a hoe at the ready. Which means I can nearly throw my shovel away! It's saved me a lot of money on rentals, and probably even more on doctor's bills.
   / To Buy or to Rent? #14
What's a shovel? ... My manual labor digging is very little now. Smarter not harder as I get older. That mini has saved me alot.
John Deere S780 Combine (A53342)
John Deere S780...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
Year: 2010 Make: Ford Model: Crown Victoria Vehicle Type: Passenger Car Mileage: Plate: Body Type... (A51694)
Year: 2010 Make...
Ford Pickup NR (A50323)
Ford Pickup NR...
