TN75DA 3pt Class II/I
   / TN75DA 3pt Class II/I #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I bought a used New Holland TN75DA. The hitch is specified as a class II/I. It is set up as a class II with larger dia. ball holes, how do you set it up to be used as a class I as all my implements are class I.
   / TN75DA 3pt Class II/I #2
I believe that you use adapters on the implement to make the pins larger and the three point check chains should be adjustable to allow them to swing in enough to fit cat 1 implements. At least on my tractors with cat 2 is how it works.
   / TN75DA 3pt Class II/I #3
You can find Cat II to I bushings for the top link and lift arms at Tractor Supply and other farm supply stores.
Steve
   / TN75DA 3pt Class II/I #4
Check your toolbox, should be replacement ends for Class I. Pretty easy to change.
   / TN75DA 3pt Class II/I #5
I have a TN70 a bought cat. 1 lower link balls and switch them out as needed. Your tractor will have slotted cat II lower link balls you can slide in and out by removing a retention pin and rotating the balls. I bought mine on e-bay for like 22 bucks each. The work fine
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
8x12 Custom Built Greenhouse (A51573)
8x12 Custom Built...
HOMEADE PIN ON 2 PRONG HAY SPEAR (A51247)
HOMEADE PIN ON 2...
1264 (A50490)
1264 (A50490)
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
