TN75D how to adjust telescopic arm ends?
   / TN75D how to adjust telescopic arm ends? #1
Fguard
Auckland, New Zealand
NH TN75D 2003
Hi rookie question, one on the telescopic ends jiggled loose during transport and I can’t figure out how to slide it back in, can anyone help?
   / TN75D how to adjust telescopic arm ends? #2
Big ole hammer
when you release them to connect equipment, backing up and lifting 3pt the ends relatch
   / TN75D how to adjust telescopic arm ends? #3
Your missing parts of your link ends.
   / TN75D how to adjust telescopic arm ends? #5
Yes there should be a pin with a ring attached to pull upward to extend arm ends. To retract with out any thing attached wiggle up and down and push in. Arm end will self lock.
Cheers, I'll try wiggling in again with a gentle tap. So pins (that are missing!) shouldn't need to be lifted when retracting?
   / TN75D how to adjust telescopic arm ends? #7
backing up and lifting 3pt the ends will relatch. If the release rings/pins are missing, I'd disassemble that top cover and get repair parts ordered. May not need this lift arm feature if using quick hitch.
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2013 Ford F150 (A55973)
2013 Ford F150...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
1992 Ingersoll Rand (A55973)
1992 Ingersoll...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
