TN75 warning lights - guide? no forward, just reverse
   / TN75 warning lights - guide? no forward, just reverse #1
OnekamaFarmer
Onekama, MI
2000 TN75S Serial# 1191136
does anyone have a TN75 warning light guide that they could share? I recently bought a 2000 New Holland TN75S at auction and a light with what looks like a book/manual and a gear next to it showed up today when I move the shuttle to the forward position. Won't go forward, just reverse. Worked fine over the last month or so. I did a search and didn't find a guide or any sort of summary. I'll be looking for a owners manual and set of service manuals in the near future. Much appreciated.
   / TN75 warning lights - guide? no forward, just reverse #2
Is the light flashing? It should be displaying two codes. IIRC, it's either flash,flash,..., pause, then flash,flash,....
Count the two codes and post them. Someone can usually look them up and give you an idea what it's not happy about (I didn't say that is really what is wrong, just what the code is supposed to mean). You will have to count them several times to get them right.
Unfortunately (or fortunately if it stays away), the problem did not replicate itself today. If it does show up again, I will take note of flash count.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2020 DRAGON ESP...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
1459 (A57192)
1459 (A57192)
2013 Ford F-550 Passenger Bus (A59230)
2013 Ford F-550...
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
