Traction TN70 won't move in 2wd / code 24
   / TN70 won't move in 2wd / code 24 #1
CHARLESBARNES
Raleigh/Durham NC
New Holland TN 70 Hohn Deere 6410
our TN 70 won't move in 2 wheel drive but will move in 4 wheel drive I am getting a code 24. Any one have any idea what a code 24 is for.
   / TN70 won't move in 2wd / code 24 #2
Code 24 is transmission clutchpacks need calibration, no calibration values are stored. This fault will not disable the transmission.
Just a wild guess, but I'll bet you have a broken rear axle half shaft. See if the tractor will move in 2WD with the differential lock engaged.
Thanks for the reply and help. We tried locking the rear end but still won't move. I guess both rear axles could be broken. We did turn both wheel and the ring gear doesn't move.
Found the problem, the planetary shaft just inside the axle shaft was wrung into. thanks for all the help.
   / TN70 won't move in 2wd / code 24 #5
That's what I suspected, referring to that shaft as a half-shaft. If the tractor didn't move in two wheel drive with the differential lock engaged, both are probably broken.
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A54865)
2004 Ford F-350...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
