Traction TN70 won't move in 2wd / code 24
   / TN70 won't move in 2wd / code 24 #1
CHARLESBARNES
Raleigh/Durham NC
New Holland TN 70 Hohn Deere 6410
our TN 70 won't move in 2 wheel drive but will move in 4 wheel drive I am getting a code 24. Any one have any idea what a code 24 is for.
   / TN70 won't move in 2wd / code 24 #2
Code 24 is transmission clutchpacks need calibration, no calibration values are stored. This fault will not disable the transmission.
Just a wild guess, but I'll bet you have a broken rear axle half shaft. See if the tractor will move in 2WD with the differential lock engaged.
Thanks for the reply and help. We tried locking the rear end but still won't move. I guess both rear axles could be broken. We did turn both wheel and the ring gear doesn't move.
Found the problem, the planetary shaft just inside the axle shaft was wrung into. thanks for all the help.
   / TN70 won't move in 2wd / code 24 #5
That's what I suspected, referring to that shaft as a half-shaft. If the tractor didn't move in two wheel drive with the differential lock engaged, both are probably broken.
Gas Pump Artwork (A55758)
Gas Pump Artwork...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
Hose Reel (A55787)
Hose Reel (A55787)
CAT 930M (A58214)
CAT 930M (A58214)
GALVANIZED MILK CAN (A58374)
GALVANIZED MILK...
