tn70 won't lift
   / tn70 won't lift #1
georaider
new holland tn70
I WAS WORKING CUTTING FIELDS UNHOOKED ONE CUTTER BACKED UP TO OTHER HOOKED UP BUT WILL NOT LIFT.UNHOOKED STILL NO LIFT CHANGED HY FILTER STILL NO LIFT HELP!!
   / tn70 won't lift #2
Do you have the automatic lift system on your tractor? I can't trmrmber exactly how it works but you either have to push the button to activate it or latch it closed to make the 3 pt controls work manually. I don't have the manual for my TD95D handy but I had a similar problem when I first got the tractor and I could not command the lift with the normal lift levers.
   / tn70 won't lift #3
draft control?
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2007 WESTERN STAR 4900 (A50854)
2007 WESTERN STAR...
TRUCKING INFO (A50775)
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
