TN65 New Holland Idle question
   / TN65 New Holland Idle question #1
rawaits
North Ga , NE Al
2003 New Holland TN65 4wd
I recently purchased an 03 TN65 and have used it twice. It has 284 hrs on it and seemed like a new one when i got it. Today, i noticed the the idle will not return to a 6-700rpm range when i cut the throttle all the way back. Rather, it stays at 1200. This happened after using it for about 40 minutes doing some light bush hogging. I first thought it might be a safeguard to cool the engine down after working. But I let the tractor sit for 2 hrs and restarted it and the idle was still 1200 with the throttle set at the lowest setting. Any ideas? Thanks, Rick
   / TN65 New Holland Idle question #2
Check for a binding cable anchor where the cable attaches to the throttle shaft plate on the injection pump.
that was it. thanks! i lubed the cable at the i p end and worked it. fixed it. many thanks, rick
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
Informational Lot - Financing (A53473)
Informational Lot...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2017 Bobcat S550 (A50123)
2017 Bobcat S550...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
