TN65 New Holland Idle question
   / TN65 New Holland Idle question #1
rawaits
North Ga , NE Al
2003 New Holland TN65 4wd
I recently purchased an 03 TN65 and have used it twice. It has 284 hrs on it and seemed like a new one when i got it. Today, i noticed the the idle will not return to a 6-700rpm range when i cut the throttle all the way back. Rather, it stays at 1200. This happened after using it for about 40 minutes doing some light bush hogging. I first thought it might be a safeguard to cool the engine down after working. But I let the tractor sit for 2 hrs and restarted it and the idle was still 1200 with the throttle set at the lowest setting. Any ideas? Thanks, Rick
   / TN65 New Holland Idle question #2
Check for a binding cable anchor where the cable attaches to the throttle shaft plate on the injection pump.
that was it. thanks! i lubed the cable at the i p end and worked it. fixed it. many thanks, rick
Dump Truck Body with Tarp System (A51691)
Dump Truck Body...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
2016 Utility 102"x48' Flatbed Trailer (A50123)
2016 Utility...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
