Oil & Fuel TN65 Fuel Consumption
   / TN65 Fuel Consumption #1
Wildcat Ranch
Oregon
New Holland TN65
Does anyone know how much fuel the TN65 uses? I cut about 17 acres this weekend and going to be doing another 6 today. Started to cut with our JD 1209 Moco but that thing is shot. After 3 hours :mad: of working on the machine adjusting it, It wasn't going to cut it. So we said enough is enough and went down and picked up a NH 616 6 disc mower.:D The only one in our area. Man is that thing nice!! Did a little over 12 acres in 3 1/2 hours! I'm needing to know fuel consumption so I can come up with a price to charge people.
Thanks,
Dan
And here's to everybody who like pictures....;)
Pic 1
Pic 2
MikePA: Changed huge inline pics to links.
   / TN65 Fuel Consumption #3
I have a TN 70A and I wish I could tell you. I bush hog for at most 1-2 hours at a time, then nothing for weeks.
2-3 gallons per hour???????????????
Let us know how it goes.
Bob
   / TN65 Fuel Consumption #4
A TN 65 huh.. I'm not real familiar with that machine.. but seem to remember 65 eng / 52 pto hp?
The closest thing i have to compair to that is a ford 5000.. it is 70 engine, and 67 pto.. I use 5g in 3 hrs while running a 10' mower.
soundguy
I checked it when cutting yesterday. Marked the site glass for the auxiliary tank and then added 5 Gal and marked again so not very accurate but I used about 5 gallons in 3 hours pulling the disc cutter. I was defiantly working the tractor. Especially in 6th gear...
Yes, the TN65 is a 65 engine / 52 pto. I wish I had a little more power. I had it turboed but the turbo started leaking oil into the intake. I took it off but I do miss it. The turbo made the engine run much smoother and cleaner....
   / TN65 Fuel Consumption #6
I would have expected a lil more fuel economy from that machine...
soundguy
   / TN65 Fuel Consumption #7
My TN70A comes with 3-cyl and a Turbo. Just thought you might want to know!!!!
   / TN65 Fuel Consumption #9
RickB said:
Emissions compliance and fuel economy are inversely porportional, or so it seems.
I guess so. While my 5000 doesn't smoke.. I guess due to age / technology.. the tn65 will have lower emissions than mine. I'm also surprised the tn65 isn't turbo charged.. that would have helped ( with emissions and fuel economy ) too, considdering the lower CID.. etc
soundguy
   / TN65 Fuel Consumption #10
My TN65 sucks around 2 gallons an hour while running my 9' discbine. So your numbers seem pretty close to mine given the fact your only powering the disc cutter and pulling a lighter implement (my TN also has FWA, larger rear tires with liquid and a loader so I am considerably heavier then your setup)
KUBOTA M7-132 (A53084)
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
