Oil & Fuel TN65 Fuel Consumption
   / TN65 Fuel Consumption #1
Wildcat Ranch
Oregon
New Holland TN65
Does anyone know how much fuel the TN65 uses? I cut about 17 acres this weekend and going to be doing another 6 today. Started to cut with our JD 1209 Moco but that thing is shot. After 3 hours :mad: of working on the machine adjusting it, It wasn't going to cut it. So we said enough is enough and went down and picked up a NH 616 6 disc mower.:D The only one in our area. Man is that thing nice!! Did a little over 12 acres in 3 1/2 hours! I'm needing to know fuel consumption so I can come up with a price to charge people.
Thanks,
Dan
And here's to everybody who like pictures....;)
Pic 1
Pic 2
MikePA: Changed huge inline pics to links.
   / TN65 Fuel Consumption #3
I have a TN 70A and I wish I could tell you. I bush hog for at most 1-2 hours at a time, then nothing for weeks.
2-3 gallons per hour???????????????
Let us know how it goes.
Bob
   / TN65 Fuel Consumption #4
A TN 65 huh.. I'm not real familiar with that machine.. but seem to remember 65 eng / 52 pto hp?
The closest thing i have to compair to that is a ford 5000.. it is 70 engine, and 67 pto.. I use 5g in 3 hrs while running a 10' mower.
soundguy
I checked it when cutting yesterday. Marked the site glass for the auxiliary tank and then added 5 Gal and marked again so not very accurate but I used about 5 gallons in 3 hours pulling the disc cutter. I was defiantly working the tractor. Especially in 6th gear...
Yes, the TN65 is a 65 engine / 52 pto. I wish I had a little more power. I had it turboed but the turbo started leaking oil into the intake. I took it off but I do miss it. The turbo made the engine run much smoother and cleaner....
   / TN65 Fuel Consumption #6
I would have expected a lil more fuel economy from that machine...
soundguy
   / TN65 Fuel Consumption #7
My TN70A comes with 3-cyl and a Turbo. Just thought you might want to know!!!!
   / TN65 Fuel Consumption #9
RickB said:
Emissions compliance and fuel economy are inversely porportional, or so it seems.
I guess so. While my 5000 doesn't smoke.. I guess due to age / technology.. the tn65 will have lower emissions than mine. I'm also surprised the tn65 isn't turbo charged.. that would have helped ( with emissions and fuel economy ) too, considdering the lower CID.. etc
soundguy
   / TN65 Fuel Consumption #10
My TN65 sucks around 2 gallons an hour while running my 9' discbine. So your numbers seem pretty close to mine given the fact your only powering the disc cutter and pulling a lighter implement (my TN also has FWA, larger rear tires with liquid and a loader so I am considerably heavier then your setup)
WB Mower (A50120)
WB Mower (A50120)
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
WOODS TBW15.40 LOT NUMBER 243 (A53084)
WOODS TBW15.40 LOT...
