TN55 - no manual!
   / TN55 - no manual! #1
mikealphahotel
UK
new Holland TN55S
Hi Folks
I have just bought a New Holland TN55S, with no prior knowledge of tractors, and no manual.
I am fine with the three point hitch, but I cannot figure out how to lower the towing hook so I can tow a trailer.
Can anyone out there help?
Thanks in advance.
Mike
   / TN55 - no manual! #2
Welcome from another UK resident. Unfortunately I cannot find anything about your tractor here
   / TN55 - no manual! #3
I'm a little bit puzzled to be honest. Is there not a drawbar on it? You may need to acquire a pin for it.
   / TN55 - no manual! #4
I thought so. If you have a look here you can see the drawbar between the lower links. That's what you need.
   / TN55 - no manual! #6
I managed to find it this morning. This is what you should have.
Messicks, I believe applies to Americaland (though no reason not to use it for clues) whereas what I've linked to applies to Englandland. Probably worth your while, Mike, to register there.
EDIT: Hmmm, that link doesn't appear to be working. Let's try this
EDIT 2: Not having much luck with my links. Looks like you'll have to start here.
   / TN55 - no manual!
Thanks Guys
Here's a link to a photo of the hook that I cannot work out how to lower or extend:
https://www.flickr.com/photos/16629153@N05/21563501484/in/dateposted-family/
Any ideas very welcome!
Thanks
Mike
   / TN55 - no manual!
I have worked out how to do it - a combination of the float control and a valve lever- so now I can buy myself a trailer!
   / TN55 - no manual! #9
Mike,
I don't know the purpose of the solid horizontal piece below the PTO shaft.
My TN55 (standard model) doesn't have that piece. I'm no expert, but I don't recall seeing anything like it on other tractors.
I can't tell from the photo -- is it bolted in place?
Steve
   / TN55 - no manual! #10
I'm probably less of an expert than smstony but, to me, that setup looks very strange.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
20" Sea Container (A47384)
20" Sea Container...
2010 FREIGHTLINER M2 BUSINESS CLASS CAB AND CHASSIS (A52472)
2010 FREIGHTLINER...
2013 PETERBILT 388 MID ROOF SLEEPER (A52472)
2013 PETERBILT 388...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
