TMGT's shop build
   / TMGT's shop build #1
TMGT
Elite Member
Stafford, VA
Kubota L3240, BX2680, ZD21, W5021
Well I've been putting off posting my build but Big Barn finally convinced me! Just as a precursor, the shop has already been built but suggestions are always welcome so hopefully others can benefit.
A couple years ago I got the go ahead to finally build my shop, I've been working out of the small 3bay attached garage since we moved to this house and while it works it was getting a bit cramped.
The max I could build without a waiver was about 2000sqft so i went with a 40x50 stick built building, because of its proximity to the house I decided to finish it the same as to not look out of place.
August of 2017 I "broke ground" after almost a year of pricing, planning and permits.
Being that my property is pretty hilly I was limited on location, it's a little closer then I'd like to the house but even there I still has to move a LOT of dirt. My arsenal was my old Case skid steer, my little Kubota CUT and my buddies old A-C HD6G track loader.841573257.jpeg475812418.jpeg1286520355.jpeg
   / TMGT's shop build
Since I live out in the middle of the woods I had a lot of trees to take down, unfortunately most were either poplar, beech, or pine which I don't burn. Did get one nice white oak and hickory out of it though.1799243608.jpeg1083859190.jpeg1577865356.jpeg752751307.jpeg
Worksite is finally coming together, luckily it stayed dry pretty much the whole time, everytime I thought I was getting close the transit said otherwise.
After a lot of work and a lot of playing musical chairs with the equipment, I finally had a buildable worksite! As you can see from the hills it was a lot of dirt moving, I even moved the building 5ft forward so I wouldn't have to move more of that hill.
   / TMGT's shop build #3
Cool TMGT! I’m following.
   / TMGT's shop build #4
Nice job on the dirt work. I'm looking forward to seeing your pics!!!
   / TMGT's shop build #5
I am waiting for it to dry up to start mine;24'x32'x12' pole barn.Never have enough storage!Already have a 24'x36'x9' and a couple smaller buildings and everything is full.Good luck on yours.
   / TMGT's shop build #6
Glad you are posting. I'm always interested in seeing the geographic obstacles others face!!!
   / TMGT's shop build #7
I live on an island (albeit a BIG one) and ALL goods gets here by air or ferry. Add THAT to construction costs.
   / TMGT's shop build
Footers done, didn't get a good picture of them working, actually didnt get nearly enough pictures of some aspects of the build. As a plus, the concrete company forgot their 16in bucket at another job so I ended up with 18in footers instead.1785132350.jpeg516786266.jpeg
I hired out the concrete work and framing, goal was I needed those done right and more importantly, done in a timely manner!
The wall forms up, the stub wall was only supposed to be 1ft but they would have had to make the forms for that height so I ended up with a 2.5ft concrete wall.759480837.jpeg88134775.jpeg
I had the guys add a few pieces of pipe in the walls so I could add stubouts for.a possible future bathroom/water and external electric.1196985002.jpeg955106370.jpeg1388019653.jpeg
   / TMGT's shop build
Thank you, I've moved a lot of dirt before but never on this scale or having to make it that level, especially with somewhat limited equipment. BTW, anyone need any fill?............
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2016 Toyota Prius Hatchback (A55758)
2016 Toyota Prius...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
43030 (A51691)
43030 (A51691)
