3-Point Hitch TLB 110 3 point hitch
/ TLB 110 3 point hitch #1
ugo4it
South shore,Nova Scotia, Canada
TLB 110
I have a 110 with no 3 point hitch and I want to fix this. Does anyone with TLB 110 have any pictures and measurement for the 3 point hitch toplink, arms and sway supports and so on?
One other option is get this info to mntviewranch (Fit Rite Hydraulics) and have set made. I seen on his site the TLB 110 is not listed. I have the three rear remotes so this is a very nice option.
So any info. would be great.
Thanks
Randy
/ TLB 110 3 point hitch #2
I'll get more detailed pics when it gets home but, I'll start with these. I forgot I had these, but took them for another member. They aren't the best, though.
/ TLB 110 3 point hitch #3
If you are starting from scratch consider a Top-n-Tilt kit. I have one from JD and it is much more versatile than the plain 3pt arms.
/ TLB 110 3 point hitch #4
He is going for a TnT, but I he's eyeing Brian's kit instead of Deere's. I can't say I'd blame him, save some money for the same basic thing. Another place to save is finding a 4000 series left over 3ph kit instead of new.
Does the kits from JD or fit rite hyd(Brian) come complete? Or do they assume you have the 3 point parts to start with. I need to get all the parts as I have none now, I would need top link, lifting arms and adjustment arms and sway links.
/ TLB 110 3 point hitch #7
Whether you get Brian's or not, you'll have to get all the links. I believe he only sells the cylinders. The links will have to come from JD or find a used pair like I posted above.
/ TLB 110 3 point hitch #9
ugo4it said:
The kit from JD look to be complete from the pictures.
What state is Cabot in?
I believe it's Arkansas. Not sure, though.
/ TLB 110 3 point hitch #10
What I would do if the set in Cabot doesn't work out is buy a set of telescopic arms from the Deere dealer and then buy the hydraulics from Brian.
This way you have the telescopic links which are much easier to hook to the big boxblades. The top n tilt is just way better too.
If I buy arms from JD which model should go looking for? I have seen talk about the 4XXX and 5XXX arms.
/ TLB 110 3 point hitch #12
The 5xxx more than likely wouldn't fit and would be cat 2. You'd want the 4xxx which is exactly the same as the 110s and is cat 1.
/ TLB 110 3 point hitch #13
If you have a good relationship with your Deere dealer you should be able to get the telescopic link arns from whole goods for about $350. When I ordered my 4520 tractor in 2009 we added two sets of these arms for about $300/set. So I have two sets left over that are the standard non telescoping variety, keeping them for backup use. I have the Deere branded topntilt and am well satisfied with it but think you can save some money going with Brian's Fit Rite Hydraulics.
This is great info. I will try to get over to Deere next weekend, and see what I can find out. Thank you all for all the help and info.
I got a reply from JD today on my question for price of a 3 point hitch kit.
They said "The 3 point hitch kit for the TLB110 is $886.00 plus HST. Any questions please let me know."
What do you guys think of this price, I am thinking its high and its not even a TnT kit, I replied by asking for the TnT pricing, see what that comes back at.
/ TLB 110 3 point hitch #16
I won't know as well as the other AKfish and Jenkinsph, but from what I've seen, that's a good price. I would have expected it to be closer to $1000. You may want to see how much it would save you to remove one side link and the top link and just get Brian's kit. The 3ph is simply said, not very cheap.
/ TLB 110 3 point hitch #17
The Craigs list deal is a very good deal, you should try and get it. The complete hitch kit from Deere with "TnT is biiiiiig money and that is if you can actually still get it. My stuff is going to run you in the $600 range. You really should check on the Craigs list stuff. ;)
2016 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
2018 CATERPILLAR 320 EXCAVATOR (A60429)
2018 CATERPILLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A60430)
2015 DODGE RAM...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2020 JOHN DEERE 26G EXCAVATOR (A60429)
2020 JOHN DEERE...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
