TL70, turn on pto or a/c and radio goes off and nothing works.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #1
robdogtn
NH TL70
Driving post month ago my dad complained my a/c wasn't working. I laughed and blew it off cause it was hot outside and I was operating the driver. Well for the last couple days it is hit or miss, but the A/C nor the PTO works. Radio works, but if I try either of the other the radio goes off. But comes right back on as soon as I turn A/C or PTO off. I can fight this for hours and no luck, or it can magically start working after I get pissed and go grab lunch and come back and start it up.
My gut feeling is a relay somewhere but in all the manuals and internet searching I see no relay that ties these components together.
Any thoughts? That is the downside to a cab tractor, no A/C, no work when it is 90+
Thanks in advance.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #2
TLs are notorious for having the ignition switch harness come disconnected / partially disconnected from the key switch. Heat damage to the switch and connector is often the result. Remove the steering column cover and check there first.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #3
Trace the red +12v cable to fuse panel, bad connection on fuse block could cause those problems. Assuming cab has a "master plug" that needs to be plugged in when cab was added, if so unplug and inspect contacts maybe use a spray contact cleaner.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #4
Probably a sneak safety switch...they dont want you to get too comfortable while using a pto...might fall asleep....just joking.
Thanks for the ideas. I have also been having issues starting, it has been hit or miss as well. I have been just jumping off to save time, but this weekend, just paying attention more and I have noticed I can cycle key without trying to start several times until the a/c fan blows, then the tractor will start and everything works as should. I can here what sounds like solenoid click when it works. Would my starter solenoid be a culprit?
   / TL70, turn on pto or a/c and radio goes off and nothing works. #6
could also be the key switch. .....just saying. not real sure how to test a key switch. i would not think that there would be a single relay that would control everything. usually the ac , the pto, etc would have their own relays and solenoids.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #7
It would probably take all of 5 minutes to get a look at the back of that key switch.
It is not the starter solenoid problem. It is not a safety switch problem. It is not likely to be a relay problem.
yes I should have stated I checked the harness on back of key switch. For sure ignition switch would be easy to replace and check. And hopefully my cheapest option as well. $50 and hour
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2022 Behnke Trailer (A55973)
2022 Behnke...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
air compressor (A55758)
air compressor...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A57880)
2014 PETERBILT 384...
