TL70, turn on pto or a/c and radio goes off and nothing works.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #1
robdogtn
NH TL70
Driving post month ago my dad complained my a/c wasn't working. I laughed and blew it off cause it was hot outside and I was operating the driver. Well for the last couple days it is hit or miss, but the A/C nor the PTO works. Radio works, but if I try either of the other the radio goes off. But comes right back on as soon as I turn A/C or PTO off. I can fight this for hours and no luck, or it can magically start working after I get pissed and go grab lunch and come back and start it up.
My gut feeling is a relay somewhere but in all the manuals and internet searching I see no relay that ties these components together.
Any thoughts? That is the downside to a cab tractor, no A/C, no work when it is 90+
Thanks in advance.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #2
TLs are notorious for having the ignition switch harness come disconnected / partially disconnected from the key switch. Heat damage to the switch and connector is often the result. Remove the steering column cover and check there first.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #3
Trace the red +12v cable to fuse panel, bad connection on fuse block could cause those problems. Assuming cab has a "master plug" that needs to be plugged in when cab was added, if so unplug and inspect contacts maybe use a spray contact cleaner.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #4
Probably a sneak safety switch...they dont want you to get too comfortable while using a pto...might fall asleep....just joking.
Thanks for the ideas. I have also been having issues starting, it has been hit or miss as well. I have been just jumping off to save time, but this weekend, just paying attention more and I have noticed I can cycle key without trying to start several times until the a/c fan blows, then the tractor will start and everything works as should. I can here what sounds like solenoid click when it works. Would my starter solenoid be a culprit?
   / TL70, turn on pto or a/c and radio goes off and nothing works. #6
could also be the key switch. .....just saying. not real sure how to test a key switch. i would not think that there would be a single relay that would control everything. usually the ac , the pto, etc would have their own relays and solenoids.
   / TL70, turn on pto or a/c and radio goes off and nothing works. #7
It would probably take all of 5 minutes to get a look at the back of that key switch.
It is not the starter solenoid problem. It is not a safety switch problem. It is not likely to be a relay problem.
yes I should have stated I checked the harness on back of key switch. For sure ignition switch would be easy to replace and check. And hopefully my cheapest option as well. $50 and hour
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
XCMG CV83PD (A53317)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2022 Ram 2500 (A55973)
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
