TL 3200
/ TL 3200 #1
hot57
Just got this tractor and Desperatly need wiring diagram. when I turn on the lights, the gages go to max . Also what is proper hydrolic fluid?? Where might I find a manual? Thanks for your help. Bud
/ TL 3200 #2
Use oil rated for john deere. I would check the ground on the gauge cluster. Usely when weard things happen it is a ground problem. Larry
/ TL 3200 #3
Sorry for how late this is.............I ran into the finding a wiring diagram problem when I purchased my TL2300 with a burnt out wiring harness and had to replace the whole thing.......
What I ended up doing was ordering a parts manual that also includes a schematic and getting help from folks on here.
After I did all that and had it installed, I happened to look up at the underside of my hood............guess what was there.........a decal with the wiring diagram on it........anyway....hope this helps.....Dennis
/ TL 3200 #4
I am one of those poor souls that bought an iseki tl3200. I can find nothing for it.Anywhere. I need a hydraulic filter canister and filter. It was so tight I put a hole in it loosening it.ANY filter numbers for it would be so great. Bill
/ TL 3200 #5
Can you post a pic of the tractor & the area the filter is located ? Some of these models are very different #,s but very similiar tractors from what I,ve been seeing latelly .
If Your filter is located obove the left rear axle like in this pic , it may be like mine & use a this which is a hastings # HA HF 993 . Hope that helps . ;)
BTW , if new members would start a new thread other then posting in a very old unrelated thread they might receive more replys . ;) Best of luck .
/ TL 3200 #6
Contact Lens12 on this site. He can usually help.
Sheaffer's Town & Country Trac
320 Palmyra RD
Dixon, IL 61021
Phone Number: (815) 284-3226
Fax Number: (815) 284-5050
Email Address: sheaftractor@grics.net
Website URL: www.sheaftractor.net
/ TL 3200 #7
Dennis,
Do you still have your Iseki tl3200? I purchased mine about a month ago. Have you found a manual? is this tractor the same as a White Field Boss 2 32 or 35?
Thanks,
Brad
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2018 FORD F-150 (A65643)
2018 FORD F-150...
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
