TL 3200
/ TL 3200 #1
hot57
Just got this tractor and Desperatly need wiring diagram. when I turn on the lights, the gages go to max . Also what is proper hydrolic fluid?? Where might I find a manual? Thanks for your help. Bud
/ TL 3200 #2
Use oil rated for john deere. I would check the ground on the gauge cluster. Usely when weard things happen it is a ground problem. Larry
/ TL 3200 #3
Sorry for how late this is.............I ran into the finding a wiring diagram problem when I purchased my TL2300 with a burnt out wiring harness and had to replace the whole thing.......
What I ended up doing was ordering a parts manual that also includes a schematic and getting help from folks on here.
After I did all that and had it installed, I happened to look up at the underside of my hood............guess what was there.........a decal with the wiring diagram on it........anyway....hope this helps.....Dennis
/ TL 3200 #4
I am one of those poor souls that bought an iseki tl3200. I can find nothing for it.Anywhere. I need a hydraulic filter canister and filter. It was so tight I put a hole in it loosening it.ANY filter numbers for it would be so great. Bill
/ TL 3200 #5
Can you post a pic of the tractor & the area the filter is located ? Some of these models are very different #,s but very similiar tractors from what I,ve been seeing latelly .
If Your filter is located obove the left rear axle like in this pic , it may be like mine & use a this which is a hastings # HA HF 993 . Hope that helps . ;)
BTW , if new members would start a new thread other then posting in a very old unrelated thread they might receive more replys . ;) Best of luck .
/ TL 3200 #6
Contact Lens12 on this site. He can usually help.
Sheaffer's Town & Country Trac
320 Palmyra RD
Dixon, IL 61021
Phone Number: (815) 284-3226
Fax Number: (815) 284-5050
Email Address: sheaftractor@grics.net
Website URL: www.sheaftractor.net
/ TL 3200 #7
Dennis,
Do you still have your Iseki tl3200? I purchased mine about a month ago. Have you found a manual? is this tractor the same as a White Field Boss 2 32 or 35?
Thanks,
Brad
2005 Ford F-250 Utility Truck, VIN # 1FDSF20P95EA36131 (A61165)
2005 Ford F-250...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
2021 Aluminum Carry-On Trailer Trailer, VIN # 4YMBU1015MG131799 (A61165)
2021 Aluminum...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
