Titan QA to 3 PT hitch
   / Titan QA to 3 PT hitch #1
Jonathan70
CT
2538 CAB HST
Any thought on using a titan QA 3 Pt hitch system with trailer box hitch also.. on the FEL OF my 2538 Mahindra ,
So that:
1) I can move trailers around,
2) I can attach my rear blade grader to it to push snow / clear the driveway.... by putting it on the FEL , I keep the backhoe on for counterbalance needed when moving trees & firewood ...
Amazon has it and Titan is selling for less with free shipping ...
THX
   / Titan QA to 3 PT hitch #2
Might be a good use for turning a grader blade into a push blade.
I just took a chance and ordered their landscape rake wheel kit again. I found it was cheaper at the pallet forks dot com than it was anywhere else including Titan dot com.
I hope they have made some changes in their packing and shipping department. I ordered this wheel set earlier in the year. It arrived in a partially open box with half the parts missing. Two phone calls later they finally shipped the replacement parts. I tracked that package till it got to Atlanta and stopped moving. FedEx said that package came apart and they didn't know if all the parts were there so I just told them to send what they had back and I did the same.
Their stuff is an excellent value if they can work some issues out.
   / Titan QA to 3 PT hitch #3
I got one several years ago and use it a lot it a lot. With a TSC carry all it becomes a poor mans fork lift, a receiver hitch and I can move my trailers when I mow lawn, take blade off my back blade and I have a boom, now I have it mounted on a snow plow I adapted for 3 pt use. It has paid for itself several times over and I love it!
   / Titan QA to 3 PT hitch #4
I have one that I use with a boom pole most of the time and it works great! I did put a quick hitch on it once to see how it would work for quickly moving attachments around and found that I could hardly see any part of the quick hitch which made it difficult to hook up without getting out of the seat. I would think the same would hold true for the receiver hitch.
   / Titan QA to 3 PT hitch #5
Several TBN folk have welded a HF quick hitch to a SSQA plate to get the same thing. It is very useful.
   / Titan QA to 3 PT hitch #6
Did that for my snow plow mount. Was handy for moving impliments & rolling my flail over for maintenance. Was sad to see it go with the old tractor & plow. Have a spare SSQA plate, need to get another cheap QH & make another.
   / Titan QA to 3 PT hitch #7
   / Titan QA to 3 PT hitch #9
How much weight do you think you can lift with the boom pole befor you did damage to the FEL ? I was thinking of lifting asphalt shingles onto a roof with some sort of basket. My forks will not reach high enough.
   / Titan QA to 3 PT hitch #10
No idea on how much it could lift but I would assume the loader would just stop lifting before it did any damage? That truck canopy probably weighs 300 plus pounds and the loader doesn't even notice it so I would assume it could lift quite a few bundles of shingles to a single story roof.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2019 INTERNATIONAL...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
Ditch Witch R 40 (A52384)
Ditch Witch R 40...
2025 K2223G UNUSED Double Garage Metal Shed (A53117)
2025 K2223G UNUSED...
