Titan QA to 3 PT hitch
   / Titan QA to 3 PT hitch #1
Jonathan70
CT
2538 CAB HST
Any thought on using a titan QA 3 Pt hitch system with trailer box hitch also.. on the FEL OF my 2538 Mahindra ,
So that:
1) I can move trailers around,
2) I can attach my rear blade grader to it to push snow / clear the driveway.... by putting it on the FEL , I keep the backhoe on for counterbalance needed when moving trees & firewood ...
Amazon has it and Titan is selling for less with free shipping ...
THX
   / Titan QA to 3 PT hitch #2
Might be a good use for turning a grader blade into a push blade.
I just took a chance and ordered their landscape rake wheel kit again. I found it was cheaper at the pallet forks dot com than it was anywhere else including Titan dot com.
I hope they have made some changes in their packing and shipping department. I ordered this wheel set earlier in the year. It arrived in a partially open box with half the parts missing. Two phone calls later they finally shipped the replacement parts. I tracked that package till it got to Atlanta and stopped moving. FedEx said that package came apart and they didn't know if all the parts were there so I just told them to send what they had back and I did the same.
Their stuff is an excellent value if they can work some issues out.
   / Titan QA to 3 PT hitch #3
I got one several years ago and use it a lot it a lot. With a TSC carry all it becomes a poor mans fork lift, a receiver hitch and I can move my trailers when I mow lawn, take blade off my back blade and I have a boom, now I have it mounted on a snow plow I adapted for 3 pt use. It has paid for itself several times over and I love it!
   / Titan QA to 3 PT hitch #4
I have one that I use with a boom pole most of the time and it works great! I did put a quick hitch on it once to see how it would work for quickly moving attachments around and found that I could hardly see any part of the quick hitch which made it difficult to hook up without getting out of the seat. I would think the same would hold true for the receiver hitch.
   / Titan QA to 3 PT hitch #5
Several TBN folk have welded a HF quick hitch to a SSQA plate to get the same thing. It is very useful.
   / Titan QA to 3 PT hitch #6
Did that for my snow plow mount. Was handy for moving impliments & rolling my flail over for maintenance. Was sad to see it go with the old tractor & plow. Have a spare SSQA plate, need to get another cheap QH & make another.
   / Titan QA to 3 PT hitch #7
   / Titan QA to 3 PT hitch #9
How much weight do you think you can lift with the boom pole befor you did damage to the FEL ? I was thinking of lifting asphalt shingles onto a roof with some sort of basket. My forks will not reach high enough.
   / Titan QA to 3 PT hitch #10
No idea on how much it could lift but I would assume the loader would just stop lifting before it did any damage? That truck canopy probably weighs 300 plus pounds and the loader doesn't even notice it so I would assume it could lift quite a few bundles of shingles to a single story roof.
(INOP) CATERPILLAR IT-38G LOADER (A51247)
(INOP) CATERPILLAR...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
FAKE (A52472)
FAKE (A52472)
APPROX. (13) NEW 24' SPAN 4/12 TRUSSES (A51248)
APPROX. (13) NEW...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
