Tires Tires
   / Tires #1
Auz
N.W. Oregon
Kubota B21
I have a spare set of front wheels for a B21. The tractor has Industrial tires all the way around now. Could I put Agricultural tires on the spare front wheels to use in the mud? The industrial front tires on it now are about 50% tread and the rears 99%, so the gearing ratios are not exactly even now. I have gravel and dirt ( soon to be mud ) only, no pavement.
   / Tires #2
Compare the circumferences of the tires that belong on the tractor with those that are on the tractor. Do the same with those that you intend to purchase. I believe that the rule of thumb is a 10% differential is allowable as long as there is slippage available.... i.e... using on turf, dirt, or snow. The circumference only comes into play when you are in 4 wheel drive, so I don't see how you can get into trouble if you keep the proper circumference the same...
9070 (A50323)
9070 (A50323)
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
Set of Tractor Tracks (A50514)
Set of Tractor...
