Tires
/ Tires #1
tarious
Grand Forks, ND
JD 3320
First of all, I want to thank all of you on this forum. I am in the process of purchasing my first compact utility tractor, and I appreciate the opinions and knowledge offered here throughout this forum.
I’ll get to the point:
R4 tires, two sizes, what are the advantages of paying for the taller tire? I will be using the tractor mainly for mowing (5 acres), light landscaping, and some bucket work. From reading other posts, the R4’s seem to be relatively easy on the grass while providing more traction then turf tires.
I have already signed the purchase agreement. The dealer is trying to locate a tractor for me today. 3320, 300cx, 72 inch rear frontier mower.
I also welcome any other suggestions, or criticisms. This is a learning process for me.
Thank you,
Jerry Slinger/tarious
tarious@hotmail.com
/ Tires #2
You probably will not be happy with turf tires if you are going to do any significant bucket work as the traction is just not there. Also, if you have any hills to mow, the R4s will provide better traction. My R4s on a NH TC45DA are pretty easy on the grass unless the ground is wet.
/ Tires #3
For your purposes, I don't see any real advantage. I wasn't actually aware that one would have a choice of a taller tire on the model.
John
/ Tires
I am confused, maybe they are not taller, perhaps just larger rims or wider tires? Here are the options:
25x8.50-14 6PR Front R4 Ind 2 Pos.
15-19.5 6PR Rear R4 Ind. 2 Pos.
Or 150.00 more for:
27x8.5-15 6PR Front R4 Ind. 2 Pos.
43x16-20 4PR Rear R4 Ind. 2 Pos.
Thanks again,
/ Tires #6
Jerry,
I just purchased the same tractor and took delivery last week. I opted for the larger R4's for similar use as you stated.
I have a 6' Bush Hog finish mower and gave the new tractor a work out last weekend. We just finished our house (at least in the final stages) and don't have the lawn in yet. My 10 acres was all fescue (now have about 2 acres of dirt!) but from what I saw I don't think the R4's will be a problem. I have a couple of areas that don't drain well and had to use the differential lock a couple of times but was able to drive right out.
Did you get a delivery date? As I posted a little while ago on the Deere forum, when I ordered mine Deere quoted a mid June delivery and said the delay was the larger R4's. So my dealer ordered with R1's and swapped tires with a 3520 he had on the floor.
Hope this helpsl
Steve
/ Tires
Thanks Steve! They told me today the tractor should be here next week, with the larger R4's.
How do you like your tractor so far? Is it what you expected? No trouble with the 6' mower?
Thanks,
/ Tires
Steve,
I am curious how you are approaching seeding the 2 acres. I am strongly considering converting some pasture into more lawn and building a small shop.
Till, herbicide, wait a week and plant grass? How do you plant the grass, some kind of grass seeder?
Thanks,
/ Tires #9
You'd have a little larger rim, 15 and a little more height. May give you better traction, and the price isn't all that much more.
John
/ Tires
Thanks John! Would the taller tire result in less HP/TQ to the ground?
Thanks,
/ Tires #11
</font><font color="blue" class="small">( Thanks John! Would the taller tire result in less HP/TQ to the ground? )</font>
I'm not a tire expert by any means, but I don't think you lose anything. I think you may gain a little as the larger tire doesn't turn as fast as the smaller tire.
Maybe someone else knows more about this, but that's my guess.
John
/ Tires #12
Jerry,
So far I love the new tractor. It's like driving a Cadillac compared to my old Ford 861. It handles the 6' finish mower with ease. Some of my fescue was over 2' tall. I was a little skeptical taking on grass that tall, but neither the tractor or mower seemed to mind a bit.
As far as seeding the yard, I'm not sure what I'll have to do for sure. As I said, I've probably got 2 acres of ground that's torn up from construction. I've got around a 450' driveway and they had to take clay out of another area to get a good base. The house isn't quite done yet and the builder still has to do the final grade. I'll see how he does. If he does a good job I should be able to just use the landscape rake to do the final dress and then seed. I may have to use the box blade first to loosen up the soil and get it the way I want it. I don't have a seeder so I'll probably borrow or rent one. Probably just a PTO driven broadcast type spreader. Then I'll drag it or roll it with something.
The summer heat is pretty gruesome here so my feeling is I'd be wasting my time trying to seed before fall. I'll probably just spend the summer doing landscaping (retaining walls, gardens, berms, patio, etc.) and seed the end of August. Although I may see if I can find some cheap rye grass to grow to control erosion during the summer rains.
There have been several threads on grass planting / growing on this site. Do a search. You also might want to check out the following sites:
http://www.lawnforums.com/
http://www.lawnsite.com/
http://www.farmseeds.com/
Hope this helps.
Steve
/ Tires #13
</font><font color="blue" class="small">( First of all, I want to thank all of you on this forum. I am in the process of purchasing my first compact utility tractor, and I appreciate the opinions and knowledge offered here throughout this forum.
Thank you,
tarious@hotmail.com )</font>
taller tires = more ground clearance but less stability.
R4 tires to me combine the worst features of A/G and Turf tires.
In mud they turn into racing slicks.
<font color="brown"> No matter which tires you have,Your tractor is going to make tracks . Why do you think they call them <font color="red">Tract-ors ? </font>
You really aren't saving much turf with industrials or turfs but you are sacrificing traction.
<font color="orange"> If it don't have AGs it's not a tractor.
</font>
/ Tires #14
You say you'll mostly be mowing. I would recommend the turf tires, they will be much kinder than ag's to your lawn. Turfs have reasonably good traction in snow. In mud not so good.
I think R4's are realy indended for pavement.
/ Tires #15
The latin root tract means to draw or pull.
but your "meaning" of leaving ruts is a bit more fun.
/ Tires #16
</font><font color="blue" class="small">( R4 tires to me combine the worst features of A/G and Turf tires.
In mud they turn into racing slicks. )</font>
If I had Ags and it was muddy, I wouldn't be using my tractor anyway because of the damage it would do, so I wouldn't lose anything by having R4. My use it what you would call property maintenance. Obviously agricultural and contruction have different requires. You probably wouldn't want to be trenching on a construction side in mud with R4s.
/ Tires #17
<font color="blue"> If it don't have AGs it's not a tractor. </font>
I disagree with that Larry... It's not a tractor unless it has gears! /forums/images/graemlins/grin.gif
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
3097 (A63117)
3097 (A63117)
