Tires Tires
/ Tires #1
santacruzer
Santa Cruz, CA
Hello,
New guy here. I'm getting a new Kubota 2350 in a week or so. My question is what tires should I get as Kubota offers 3 treads. The "turf" tire is out so it's between the "bar" tread and the "industrial" tread.
Most of the use will be on dirt but I'm afraid the "bar" tread will tear the ground up too much but fear the "industrial" tread will wind up spinning in the dirt,even though the "industrial" tread is fairly aggressive.
The tractor is 4 x 4 with differential lock.
I appreciate any feed back anyone may have.
Thanks, Paul
/ Tires #2
I have a BX 2350 with the r-4 industrial tires. I use my tractor for a variety of things. I plow my driveway in the winter (asphalt) with a rear blade and the loader. In the summer i mow my lawn (60" mmm). I do limited loader work.
I have never had a traction issue. With the 4x4 and the differential lock - I have always been able to do what I wanted.
I think the Ag tires are too aggressive if you will use the tractor on a lawn. The bars on the industrial tires are wide enough that they "float" very well.
If all you will be doing is working in the dirt (no lawn), then I would go with the Ag's.
/ Tires #3
Go for the ag tires. I find on my Agco st30x that I run out of traction before I run out of HP. If you are carefull you can minimize the damage from the tires. I am forced to lock the diff and use 4wd more than I think should be needed.
I wish I would have got ag tires.
SactoValley
/ Tires #4
I have a BX24 with the R-4 tires. R1's weren't an option on the BX24, I'm told due to the slearance issues between the bars and the backhoe.
Anyway, I've been doing a lot of dirt work (loader, backhoe, moving large rocks, brush moving) and the only time I spin the wheels is when I'm not in 4WD and should be (like digging into a large dirt pile). 4WD and an occasional use of the diff lock pedal has worked fine. The R4's also ride pretty well on our asphalt drivesays.
/ Tires #5
I'd go with the R4's, in fact I did! My tractor guy explained that the ag tires will give you grooves after a few mows following the same route (like the edges on the property). My neighbor is a HE operator and told me the same thing. So far I have used the diff lockout once and 4wd twice for a few feet (**** groundhog). The R4 is slightly less agressive than the Ag tires.
BTW I got my 2350 two days ago and I couldn't be happier, you'll enjoy yours.
Just go slow and gain experience then tackle the big projects.
/ Tires #6
Fear not... the industrial tires will provide sufficient traction..seldom if ever slip, and if they do, there is a reason
/ Tires #8
santacruzer said:
Hello,
Thanks, Paul
Bar by far.
Today I found out 4wd front turfs and wet soft spots don't go good togrther.
/ Tires #10
I don't know if the ag tires are higher ply now or not but my ag tires on my 23 are very thin. I had to patch one a while back and the inside of it looked like a porcupine with all the thorns in it. If it wasn't for the slime in them I wouldn't be able to work a day without patching the tires. I am going to get the r4s for it this summer as they are much thicker than my tires.
Right now I have two sticks in my front tire that I need to patch, which gets to be a mess with the slime in there.
/ Tires #12
I have the R4s and am very happy. I do use chains on the ice but haven't been able to get it stuck yet. I only have 45 hours since March 6th. I seem to have a slight leak which i cannot find in the front left. Noticed it with a full load of stone in the bucket.
/ Tires #13
santacruzer said:
1*My question is what tires should I get as Kubota offers 3 treads. The "turf" tire is out so it's between the "bar" tread and the "industrial" tread.
2* I'm afraid the "bar" tread will tear the ground up too muchi
but
3*fear the "industrial" tread will spin.
Paul
1*Bar = the only to fly!
2*I think that is a blown out of proportion fear and don't believe it even applies to the small compacts and sub compacts except in rare or unusual circumstances.
It may come into play on utility and larger tractors, however.
I have a BX23 with the AG tires and have driven it 970 hours all over my 2.33 acres. I have never had the FEL MMM or BH off it.
There has been no yard damage or other problems from the tires.
3* Industrials are not self cleaning like the Bar tires are so they fill up with mud and turn into racing slicks offering little or no traction in that situation.
Another bad deal is Turfs on the front of a 4 x4 tractor.
Get on a soft spot and they will spin and really rut up the ground even when the rear tires are on solid ground with plenty of traction and not spinning.
I got into that yesterday.
/ Tires #15
smallfarmer said:
My tractor guy explained that the ag tires will give you grooves after a few mows following the same route (like the edges on the property). My neighbor he is a HE operator and told me the same thing.
970 hours driving 0n my 2.33 acres with my BX23 with AGs.
Never had the MMM FEL or BH off the tractor.
How many hundreds more hours before i start seeing signs of the groves?
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Bobcat SC72 (A64127)
